.NET
Possible to reuse Point2d's? (c#)
1 REPLY 1
Matt S
439 Views, 1 Reply
I know Point2d is a managed class, so it would seem that one would be able to set the X and Y values. Maybe I am missing something, but I can't find any way to do ths. The X and Y properties are read only. I haven't tried to use Transformby() to modify the point to a new location becuase it seems easier to just make new points. In ARX one could set values into the AcGePoint2d objects, why can't we do that in .NET? If we can, why haven't I been able to find a way? No need to answer the second question. 🙂
Any help is appreciated
1 REPLY 1
in reply to: Matt S
In VB.NET it would be something like:
Dim x as Double = 10
Dim y as Double = 20
Dim MyPoint as Point2d = New Point2d(x , y)
Or
... code in here ...
MyPoint = New Point2d(x , y)
After you have set MyPoint object, you can read the x and y values with:
x = MyPoint.X
y = MyPoint.Y
Hope you get the idea.
/ Tomi
kirjoitti viestissä:5034821@discussion.autodesk.com...
”Boost
