.NET
GStevens
Message 1 of 6 (336 Views)
Polyline3d intersect
336 Views, 5 Replies
05-11-2006 07:49 PM
Hello everyone,
1. How to get the intersection of 2 Polyline3d in different plane?
I tried using IntersectWith() but it return no intersection because the polylines lies in different plane.
2. How about Aparent Intersect? Is there anyone who can teach me how to implement this in my C# code?
Thank you.
GS
Distinguished Contributor
Alexander Rivilis
Message 2 of 6 (336 Views)
Re: Polyline3d intersect
05-12-2006 06:08 AM in reply to: GStevens
What about create projections of those Polyline3d on single plan (with help of Polyline3d.GetProjectedCurve method)?
After than you can do IntersectWith() with projections.
GStevens
Message 3 of 6 (336 Views)
05-12-2006 11:35 PM in reply to: GStevens
Dear Alexander Rivilis,
I'll do that. Thank you.
GS
GStevens
Message 4 of 6 (336 Views)
05-12-2006 11:46 PM in reply to: GStevens
I'll appreciate if you can show me a snippet code how to do it.
Thank you in advance.
GS
Alexander Rivilis
Message 5 of 6 (336 Views)
05-13-2006 01:55 AM in reply to: GStevens
[code]
using System ;
using System.Collections;
using Autodesk.AutoCAD.Runtime ;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.ApplicationServices;
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
[assembly: CommandClass(typeof(ClassLibrary.Class))]
namespace ClassLibrary
public class Class
[CommandMethod("IntPoly3d")]
static public void IntPoly3d()
Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
Polyline3d pl1 = SelectPoly3d("\nSelect first Polyline3d: ");
if (pl1 == null) return;
Polyline3d pl2 = SelectPoly3d("\nSelect second Polyline3d: ");
if (pl2 == null) return;
// We can project our plines in direction of Z axis of WCS,
// but you can use another project plane
Vector3d dir = new Vector3d(0,0,1);
Point3d orig = new Point3d (0,0,0);
// Plane of WCS
Plane planeWCS = new Plane(orig, dir);
Curve pl1_prj = pl1.GetProjectedCurve(planeWCS,dir); pl1.Dispose();
Curve pl2_prj = pl2.GetProjectedCurve(planeWCS,dir); pl2.Dispose();
Point3dCollection pts = new Point3dCollection();
pl1_prj.IntersectWith(pl2_prj,Intersect.OnBothOperands,pts,0,0);
if (pts.Count > 0)
ed.WriteMessage("\nNumber of intersection: {0}",pts.Count);
foreach (Point3d pt in pts) ed.WriteMessage("\n Point: {0}",pt);
else
ed.WriteMessage("\nNo intersection!");
pl1_prj.Dispose(); pl2_prj.Dispose();
static private Polyline3d SelectPoly3d(string str)
Database db = HostApplicationServices.WorkingDatabase;
PromptEntityResult rs = ed.GetEntity(str);
if (rs.Status == PromptStatus.OK)
Transaction trans = db.TransactionManager.StartTransaction();
Entity ent = (Entity)trans.GetObject(rs.ObjectId, OpenMode.ForRead);
Polyline3d pl = ent as Polyline3d;
trans.Commit();
if (pl == null) ed.WriteMessage("\nIt is not Polyline3d!");
return pl;
return null;
[/code]
GStevens
Message 6 of 6 (336 Views)
05-14-2006 09:36 PM in reply to: GStevens
Thank you so much to your help it helps me a lot however its my mistake that I was not able to inform you that I need also the value of Z coordinate. What should I do so that I get also get it like Apparent Intersect does?
Once again thank you.
GS
