.NET
Active Contributor
xdbk07
Message 1 of 7 (464 Views)
Polyline with Arc
464 Views, 6 Replies
08-23-2013 12:36 AM
Hi everyone,
I'm having a problem when I create polyline with arc using vb.net. The arc is a quarter of ellipse. Please see picture below for detail.
Thanks any helps.
Thank Gilles. This is exactly what I’m looking for.
Active Contributor
R.Gerritsen4967
Message 2 of 7 (457 Views)
Re: Polyline with Arc
08-23-2013 12:52 AM in reply to: xdbk07
An ellipse is not an arc and cannot be joined to a polyline.
Maybe you can try to facet the ellipse. With this you turn the ellipse into a polyline that's almost (but not exactly!) following the same path as the ellipse.
Here's an excellent explanation, including some code...
http://through-the-interface.typepad.com/through_the_interface/2009/12/faceting-autocad-curves-using...
Active Contributor
xdbk07
Message 3 of 7 (451 Views)
08-23-2013 01:10 AM in reply to: R.Gerritsen4967
How about SPLINE! Can we create a spline like blue arc (in picture)?
_gile
Message 4 of 7 (433 Views)
Re : Polyline with Arc
08-23-2013 04:38 AM in reply to: xdbk07
Have a look at the GeometryExtensions library, specialy the PolylineSegment and PolylineSegmentCollection classes.
There's an example on how to use them here.
Gilles Chanteau
Active Contributor
xdbk07
Message 5 of 7 (412 Views)
08-24-2013 12:31 AM in reply to: _gile
Thank for help. Are there any way to draw only a quarter of ellipse.
_gile
Message 6 of 7 (404 Views)
08-24-2013 03:47 AM in reply to: xdbk07
You can set the StartAngle and EndAngle properties of the Ellipse instance. Angles are measured in radians CCW from the MajorAxis vector.
Gilles Chanteau
Active Contributor
xdbk07
Message 7 of 7 (362 Views)
08-27-2013 10:39 PM in reply to: _gile
