.NET
Polyline point at given distance
1 REPLY 1
962 Views, 1 Reply
Hi
I am trying to get point on polyline at given distance from point i choose. Synce GetPointAtDist only uses polyline start point  I tryed to brake polyline so startpoint to be at start point of measurement but I get eNotin database? Anyone have idea what I am doint wrong??
Here's my code:
 [CommandMethod("stacpoly", CommandFlags.Modal)]
        public void stacpoly() // This method can have any name
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            ObjectId pid = funkcije.odaberi_polyline("Od poly");
            Point3d t = funkcije.pp("Odaberi tocku");
            Point3d t1=default(Point3d);
            Point3d t2 = default(Point3d);
            using (Transaction tr = db.TransactionManager.StartTransaction())
                Polyline pline = (Polyline)tr.GetObject(pid, OpenMode.ForWrite);
                if (pline.EndPoint.X<pline.StartPoint.X)
                  try
                      pline.ReverseCurve();
                  catch( Autodesk.AutoCAD.Runtime.Exception ex)
                    ed.WriteMessage(ex.Message);
                t = pline.GetClosestPointTo(t,false);
                Point3dCollection tpoly = new Point3dCollection();
                tpoly.Add(pline.StartPoint);
                tpoly.Add(t);
                tpoly.Add(t);
                tpoly.Add(pline.EndPoint);
                DBObjectCollection plines = pline.GetSplitCurves(tpoly);
                if (plines.Count==2)
                    Polyline p1;
                    Polyline p2;
                    DBObject dbo1 = plines[0];
                    try
                       p1 = (Polyline)dbo1;
                       tr.AddNewlyCreatedDBObject(dbo1, true);
                       p1.ReverseCurve();
                       DBObject dbo2 = plines[1];
                       p2 = (Polyline)dbo2;
                       tr.AddNewlyCreatedDBObject(p2, true);
                       t1 = p1.GetPointAtDist(200);
                       t2 = p2.GetPointAtDist(200);
                    catch (Autodesk.AutoCAD.Runtime.Exception ex)
                tpoly.Dispose();
                plines.Dispose();
                pline.Erase();
                tr.Commit();
            Line l1 = new Line(new Point3d(0, 0, 0), t1);
            Line l2 = new Line(new Point3d(0, 0, 0), t2);
1 REPLY 1
Jeff_M
Why not just use GetDistAtPoint() and add the desired distance to that to pass to GetPointAtDist()?
Jeff_M, also a frequent Swamper
”Boost
