.NET
Polyline How To
5 REPLIES 5
776 Views, 5 Replies
Polyline How To
I want to draw a complex polyline with both arcs and straight lines. I look at the polyline constructor and see that I can give the vertices for the polyline. but, how can I set whether the vertices connection a line or and arc?
I'm not finding much in the way of documentation on the polyline functions.
Can someone direct me to examples or documentation? Please?
5 REPLIES 5
I wait that this you is useful
Dim pline As New Autodesk.AutoCAD.DatabaseServices.Polyline()
pline.AddVertexAt(0, p0, 0, 0, 0)
pline.AddVertexAt(1, p1, 0.414214, 0, 0)
pline.AddVertexAt(2, p2, 0, 0, 0)
pline.AddVertexAt(3, p3, 0.414214, 0, 0)
pline.AddVertexAt(4, p4, 0, 0, 0)
pline.AddVertexAt(5, p5, 0.414214, 0, 0)
pline.AddVertexAt(6, p6, 0, 0, 0)
pline.AddVertexAt(7, p7, 0.414214, 0, 0)
pline.Closed = True
tp
escreveu na mensagem news:5391515@discussion.autodesk.com...
look
and
arc?
functions.
I'm protected by SpamBrave
http://www.spambrave.com/
Thanks, that did help. I didn't quite understand that bulge meant arc segment.
It sounds more like a line width or something.
Anyway, thanks a lot. I've got a much better understanding of polylines now that I understand the bulge property.
I'm still curious about how you arrived at the bulge value of 0.414214. It works, for what I want but I'd be eager to learn more about calculating bulge values for different effects.
Perhaps annexed images can help.
tp
escreveu na mensagem news:5394622@discussion.autodesk.com...
segment.
now
It
Annexed Bulge formula
tp
segment.
now
It
cgay
See a good description here:
http://www.theswamp.org/index.php?PHPSESSID=t0df37l5turcu6p4u8iflnss53&page=18
C
”Boost
