.NET
tcorey
Message 1 of 4 (138 Views)
PointPromptResult and Point2D Compatibility
138 Views, 3 Replies
04-30-2012 11:54 PM
Dim ptll AsPromptPointResult
Dim ptlr AsPoint2d
ptll = acDoc.Editor.GetPoint(PrmtPointOpt)
ptlr = PolarPoints(ptll, 0, desFrameWid)
The code above creates a point called ptll using the GetPoint function. The code that creates ptlr wants a Point2d as its basepoint arguement, but ptll is a PromptPointResult and causes an error when I plug it in as basepoint.
Does anyone know how to convert a PromptPointResult into a Point2D?
TIA,
Tim
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
tcorey
Message 2 of 4 (135 Views)
Re: PointPromptResult and Point2D Compatibility
05-01-2012 12:12 AM in reply to: tcorey
Never mind, I figured it out. I guess I should think just a little before posting.
To solve it, I created X,Y variables from the promptpointresult object and substituted those into the x,y values of a point2d object, and then used that as the basepoint.
Tim Corey, Owner
Redding, CA
Alfred.NESWADBA
Message 3 of 4 (134 Views)
05-01-2012 12:14 AM in reply to: tcorey
look to this (and don't forget to declare varaibles so you get the message of some issues at the moment you write your code!
'assuming you have the following statement on top of your codefile
Imports Autodesk.AutoCAD
Dim ptll as EditorInput.PromptPointResult ptll = acDoc.Editor.GetPoint(PrmtPointOpt) if ptll.Status = EditorInput.PromptStatus.OK then 'so we know the query for the point was not ESCaped dim pt as Geometry.Point3D = ptll.Value 'now you can goon
- alfred -
[EDIT] ok, to late [/EDIT]
Alfred NESWADBA
tcorey
Message 4 of 4 (109 Views)
05-01-2012 03:44 PM in reply to: tcorey
Thanks, Alfred.
Tim Corey, Owner
Redding, CA
