.NET
PointMonitorEventHandler Help
6 REPLIES 6
HJohn1
2023 Views, 6 Replies
I have created a PointMonitorEventHandler to add additional info whenever the cursor is over a BlockReference, the Name, the number of inserts and also identify it when it is a dynamic block.  The code works most of the time, however sometimes is crashes as a lead balloon. I have no idia what is causing it to fail.  Someone please take a look at the code and see if you can help me find out where is the error or how to implement this handler properly.  I will really appreciate any help.  Thanks.  I am using AutoCAD 2012 Mechanical <Vanilla> on 64bit Windows 7.
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Runtime
<Assembly: ExtensionApplication(GetType(AutoCADPlugin.AppEventClass))>
Public Class AppEventClass
    Implements Autodesk.AutoCAD.Runtime.IExtensionApplication
Public Sub Initialize() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Initialize
	AddHandler Application.DocumentManager.DocumentCreated, AddressOf Me.DocumentCreated_Handler
End Sub
Private Sub DocumentCreated_Handler(ByVal sender As Object, ByVal e As DocumentCollectionEventArgs)
	AddHandler Application.DocumentManager.MdiActiveDocument.Editor.PointMonitor, New PointMonitorEventHandler(AddressOf Me.EditorPointMonitor_Handler)
End Sub
 Private Sub EditorPointMonitor_Handler(ByVal sender As Object, ByVal e As Autodesk.AutoCAD.EditorInput.PointMonitorEventArgs)
        Dim anonymousIds As ObjectIdCollection
        Dim BlkRefs As ObjectIdCollection
        Dim fullpaths() As FullSubentityPath
        Dim BlkTblRec As BlockTableRecord
        Dim BlkName As String = ""
        Dim Blk As BlockReference
        Dim msg As String = ""
        Dim Total As Integer
        Dim value As Integer
        Dim Ent As Entity
        Dim id As ObjectId
        Dim idd As ObjectId
        Try
            Using trans = Application.DocumentManager.MdiActiveDocument.Database.TransactionManager.StartTransaction
                Using dlock = Application.DocumentManager.MdiActiveDocument.LockDocument
                    If Application.DocumentManager.MdiActiveDocument.Editor.IsQuiescent = False Then
                        Exit Sub
                    Application.DocumentManager.MdiActiveDocument.Editor.TurnForcedPickOn()
                    fullpaths = e.Context.GetPickedEntities
                    If fullpaths.Length = 0 Then
                        Exit Sub
                    Ent = trans.GetObject(fullpaths(0).GetObjectIds(0), OpenMode.ForRead)
                    If TypeOf Ent Is BlockReference Then
                        Blk = CType(Ent, BlockReference)
                        If Blk.IsDynamicBlock = True Then
                            BlkTblRec = CType(trans.GetObject(Blk.DynamicBlockTableRecord, OpenMode.ForRead), BlockTableRecord)
                            BlkName = BlkTblRec.Name
                            anonymousIds = BlkTblRec.GetAnonymousBlockIds
                            For Each id In anonymousIds
                                BlkTblRec = CType(trans.GetObject(id, OpenMode.ForRead), BlockTableRecord)
                                BlkRefs = BlkTblRec.GetBlockReferenceIds(False, False)
                                For Each idd In BlkRefs
                                    Total = Total + 1
                                Next
                            Next
                            msg = "Dynamic Block" & vbCrLf
                        Else
                            BlkName = Blk.Name
                            BlkTblRec = CType(trans.GetObject(Blk.BlockTableRecord, OpenMode.ForRead), BlockTableRecord)
                            Total = BlkRefs.Count
                        value = CShort(Application.GetSystemVariable("ROLLOVERTIPS"))
                        If Not value = 0 Then
                            Application.SetSystemVariable("ROLLOVERTIPS", 0)
                        msg = msg & String.Format("Block Name: {0}", BlkName) & vbCrLf
                        msg = msg & String.Format("Block Inserts: {0}", Total) & vbCrLf
                        e.AppendToolTipText(msg)
                            Application.SetSystemVariable("ROLLOVERTIPS", value)
                    trans.Commit()
                End Using
            End Using
        Catch ex As Exception
            System.Windows.Forms.MessageBox.Show(ex.Message, "Error", System.Windows.Forms.MessageBoxButtons.OK, Windows.Forms.MessageBoxIcon.Error)
        End Try
    End Sub
End Class
Here are the error message I am getting
6 REPLIES 6
Jeff_M
in reply to: HJohn1
Not much help, but I can't seem to get it to crash inside Civi3d 2012. Works with dynamic blocks, regular blocks, xrefs. I will leave it running to see if it will finally fail, but for now I have no idea why it crashes for you.
Jeff_M, also a frequent Swamper
_gile
in reply to: HJohn1
I tried to rewrite it my way, it worked fine for all the test I made.
Main changes are:
  • Adding the handler to all already opened documents when the app is loaded.
  • Checking the object type before opening it with ObjectId.ObjectClass.
  • Removing the document locking wich is not mandatory in this case.
  • Using StartOpenCloseTransaction which is cheaper and recommended within event handlers.
  • Checking if the block reference is inserted in the current space to avoid counting nestied blocks.
C# code
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
[assembly: ExtensionApplication(typeof(PointMonitorExtensionApplication.AppEventClass))]
namespace PointMonitorExtensionApplication
    public class AppEventClass : IExtensionApplication
        DocumentCollection docMan = Application.DocumentManager;
        public void Initialize()
            foreach (Document doc in docMan) doc.Editor.PointMonitor += OnPointMonitor;
            docMan.DocumentCreated += OnDocumentCreated;
        void OnDocumentCreated(object sender, DocumentCollectionEventArgs e)
            e.Document.Editor.PointMonitor += OnPointMonitor;
        void OnPointMonitor(object sender, PointMonitorEventArgs e)
            short tips = (short)Application.GetSystemVariable("ROLLOVERTIPS");
            try
                Document doc = Application.DocumentManager.MdiActiveDocument;
                Database db = doc.Database;
                Editor ed = doc.Editor;
                if (!ed.IsQuiescent)
                    return;
                ed.TurnForcedPickOn();
                FullSubentityPath[] paths = e.Context.GetPickedEntities();
                if (paths.Length == 0)
                    return;
                ObjectId id = paths[0].GetObjectIds()[0];
                if (id.ObjectClass != RXClass.GetClass(typeof(BlockReference)))
                    return;
                int cnt = 0;
                string name;
                bool isDyn;
                using (Transaction tr = db.TransactionManager.StartOpenCloseTransaction())
                    BlockReference br = (BlockReference)tr.GetObject(id, OpenMode.ForRead);
                    isDyn = br.IsDynamicBlock;
                    BlockTableRecord btr = isDyn ?
                        (BlockTableRecord)tr.GetObject(br.DynamicBlockTableRecord, OpenMode.ForRead) :
                        (BlockTableRecord)tr.GetObject(br.BlockTableRecord, OpenMode.ForRead);
                    name = btr.Name;
                    ObjectId cSpaceId = db.CurrentSpaceId;
                    foreach (ObjectId brId in btr.GetBlockReferenceIds(true, false))
                        BlockReference insert = (BlockReference)tr.GetObject(brId, OpenMode.ForRead);
                        if (insert.OwnerId == cSpaceId) cnt++;
                    if (isDyn)
                        foreach (ObjectId anonId in btr.GetAnonymousBlockIds())
                            BlockTableRecord anonBtr = (BlockTableRecord)tr.GetObject(anonId, OpenMode.ForRead);
                            foreach (ObjectId brId in anonBtr.GetBlockReferenceIds(true, false))
                    tr.Commit();
                Application.SetSystemVariable("ROLLOVERTIPS", 1);
                e.AppendToolTipText(string.Format("{0}Block Name: {1}\nBlock Inserts: {2}",
                    isDyn ? "Dynamic Block\n" : "",
                    name,
                    cnt));
            catch (System.Exception exn)
                Application.ShowAlertDialog(exn.Message);
            finally
                Application.SetSystemVariable("ROLLOVERTIPS", tips);
        public void Terminate() { }
VB translation
<Assembly: ExtensionApplication(GetType(PointMonitorExtensionApplication.AppEventClass))>
Namespace PointMonitorExtensionApplication
        Implements IExtensionApplication
        Private docMan As DocumentCollection = Application.DocumentManager
            For Each doc As Document In docMan
                AddHandler doc.Editor.PointMonitor, AddressOf EditorPointMonitor_Handler
            Next
            AddHandler docMan.DocumentCreated, AddressOf DocumentCreated_Handler
        End Sub
        Public Sub Terminate() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Terminate
        End Sub
        Private Sub DocumentCreated_Handler(sender As Object, e As DocumentCollectionEventArgs)
            AddHandler e.Document.Editor.PointMonitor, AddressOf EditorPointMonitor_Handler
        End Sub
        Private Sub EditorPointMonitor_Handler(sender As Object, e As PointMonitorEventArgs)
            Dim tips As Short = CShort(Application.GetSystemVariable("ROLLOVERTIPS"))
            Try
                Dim doc As Document = Application.DocumentManager.MdiActiveDocument
                Dim db As Database = doc.Database
                Dim ed As Editor = doc.Editor
                If Not ed.IsQuiescent Then
                    Return
                Dim paths As FullSubentityPath() = e.Context.GetPickedEntities()
                If paths.Length = 0 Then
                    Return
                Dim id As ObjectId = paths(0).GetObjectIds()(0)
                If id.ObjectClass <> RXClass.GetClass(GetType(BlockReference)) Then
                    Return
                Dim cnt As Integer = 0
                Dim name As String
                Dim isDyn As Boolean
                Using tr As Transaction = db.TransactionManager.StartOpenCloseTransaction()
                    Dim br As BlockReference = DirectCast(tr.GetObject(id, OpenMode.ForRead), BlockReference)
                    Dim btr As BlockTableRecord = _
                        If(isDyn, _
                           DirectCast(tr.GetObject(br.DynamicBlockTableRecord, OpenMode.ForRead), BlockTableRecord), _
                           DirectCast(tr.GetObject(br.BlockTableRecord, OpenMode.ForRead), BlockTableRecord))
                    name = btr.Name
                    Dim cSpaceId As ObjectId = db.CurrentSpaceId
                    For Each brId As ObjectId In btr.GetBlockReferenceIds(True, False)
                        Dim insert As BlockReference = DirectCast(tr.GetObject(brId, OpenMode.ForRead), BlockReference)
                        If insert.OwnerId = cSpaceId Then
                            cnt += 1
                    Next
                    If isDyn Then
                        For Each anonId As ObjectId In btr.GetAnonymousBlockIds()
                            Dim anonBtr As BlockTableRecord = DirectCast(tr.GetObject(anonId, OpenMode.ForRead), BlockTableRecord)
                            For Each brId As ObjectId In anonBtr.GetBlockReferenceIds(True, False)
                                    cnt += 1
                            Next
                        Next
                    tr.Commit()
                End Using
                e.AppendToolTipText(String.Format("{0}Block Name: {1}" & vbLf & "Block Inserts: {2}", _
                                                  If(isDyn, "Dynamic Block" & vbLf, ""), _
                                                  name, _
                                                  cnt))
            Catch ex As System.Exception
            Finally
            End Try
        End Sub
    End Class
End Namespace
Gilles Chanteau
GileCAD
GitHub
HJohn1
in reply to: _gile
Gilles,
Thank you for your help.  I made some modifications based on your code, but I keep on crashing.  I found that the crash occurs on the call to e.AppendToolTipText() method.  I also found the following message on the immediate window:
System.Windows.Media.Animation
Warning: 6 : Unable to perform action because the specified Storyboard was never applied to this object for interactive control.;
Action='Stop';
Storyboard='System.Windows.Media.Animation.Storyboard';
Storyboard.HashCode='9191763';
Storyboard.Type='System.Windows.Media.Animation.Storyboard';
TargetElement='Autodesk.Internal.Windows.ToolTip';
TargetElement.HashCode='22042256';
TargetElement.Type='Autodesk.Internal.Windows.ToolTip'
 Any suggestiongs?
HJohn1
in reply to: HJohn1
Can someone using AutoCAD Mechanical please run the code I posted to see if it crashes?  I have a suspicion that it might be related to the implementation of the tool tip AC M, but I am not sure about it.
Balaji_Ram
in reply to: HJohn1
Hi John,
Sorry, I havent been able to reproduce the crash during my testing.
I have tried the code with vanilla AutoCAD 2012 / 2014 and AutoCAD Mechanical 2014. I do not have AutoCAD Mechanical 2012 installed in my system, so could not test with that setup.
A few basic suggestions to narrow down the problem :
1) Do you have all the service packs installed ?
2) Can you please try with a sample project that does nothing but append to the tool tip text in the point monitor ?
3) Can you please try on any other system to see if it is reproducible there ?
Balaji
Developer Technical Services
Autodesk Developer Network
HJohn1
in reply to: Balaji_Ram
Balaji thank you very much for your help.  I ran the code in another machine running AutoCAD 2014 on 64bit Windows 7 and could not get it to crash either.  There most be something on my dev machine that is making it crash.  I will run more tests on other machines.  Thank you again.
”Boost
