.NET
PointMonitor conflicts with Dynamic Input
5 REPLIES 5
414 Views, 5 Replies
Hi everyone,
My solution based on watching Editor.PointMonitor
events seems to conflict with Dynamic Input (?!)... What I'm doing is firing a
modal dialog (the one that never receives a focus) when PointMonitor
intercepts certain entities within pickbox. I also tried with custom
System.Drawing.Graphics (no dialog) solution and all, but AutoCAD crashes as
soon as Dynamic Input toolboxes start to appear. Other "regular" tooltips (like
OSNAP's) work just fine, side-by-side with my app.
Maksim Sestic
5 REPLIES 5
You can't display a modal dialog from that kind
of event, and expect anything to work.
Did you ever see an application of any type that
pops up modal dialogs in response to nothing
but cursor movement ?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
"Maksim Sestic" wrote in message news:5247664@discussion.autodesk.com...
Hi everyone,
My solution based on watching Editor.PointMonitor events seems to conflict with Dynamic Input (?!)... What I'm doing is firing a modal dialog (the one that never receives a focus) when PointMonitor intercepts certain entities within pickbox. I also tried with custom System.Drawing.Graphics (no dialog) solution and all, but AutoCAD crashes as soon as Dynamic Input toolboxes start to appear. Other "regular" tooltips (like OSNAP's) work just fine, side-by-side with my app.
Maksim Sestic
I also tried creating a simple Graphics canvas
(say, Tooltip-alike) being fired by PointMonitor, and it still conflicts with
Dynamic Input. Everything else works just fine. BTW, modal dialog I'm
firing does not receive a focus (ever), receives only mouse
input and does not interfere with ACAD in any other way. There is
something tricky about Dynamic Input implementation (2006), and I'm suspecting
it's related to "TextBox" input control.
Now, have you ever seen a "tooltip" that gains a
focus over it's parent? 🙂 That's exactly what DYN does. This is "no good"
and I would never go down that path myself. Instead, I would make a "fake" input
control tied to ACAD's keyboard hook, an exact replica of a classic TextBox
(cursor blinking, etc.) if that was the point.
Maksim Sestic
You can't display
work.
pops up modal
href="http://www.caddzone.com">
size=2>http://www.caddzone.com
size=2>AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
href="http://www.acadxtabs.com">
size=2>http://www.acadxtabs.com
size=2>"Maksim Sestic" <
face=Verdana size=2>info@geoinova.com
wrote in message
face=Verdana size=2>news:5247664@discussion.autodesk.com
face=Verdana size=2>...
Hi everyone,
app.
Maksim Sestic
A little correction to my original
post:
Dynamic Input crashes my app only if DYNMODE >
1
Now that's funny. What's there in Dymensional
Input that's not in Pointer Input mode?
is something tricky about Dynamic Input implementation (2006), and I'm
suspecting it's related to "TextBox" input control.
a focus over it's parent? 🙂 That's exactly what DYN does. This is "no
good" and I would never go down that path myself. Instead, I would make a
"fake" input control tied to ACAD's keyboard hook, an exact replica of a
classic TextBox (cursor blinking, etc.) if that was the point.
Maksim Sestic
Did you
to nothing
2004/2005/2006/2007
face=Verdana size=2>http://www.acadxtabs.com
face=Verdana size=2>"Maksim Sestic" <
href="mailto:info@geoinova.com">
> wrote in
message
Hi everyone,
app.
Maksim Sestic
"BTW, modal dialog I'm firing does not receive a focus (ever),
receives only mouse input and does not interfere with ACAD
in any other way. "
How can that be? A modal dialog disables the AutoCAD window.
That's the definition of 'modal' - the user is forced to interact
with that dialog, and cannot access the other windows in the
application until they close it.
Perhaps you are confusing modal and modeless ?
"Maksim Sestic" wrote in message news:5248584@discussion.autodesk.com...
I also tried creating a simple Graphics canvas (say, Tooltip-alike) being fired by PointMonitor, and it still conflicts with Dynamic Input. Everything else works just fine. BTW, modal dialog I'm firing does not receive a focus (ever), receives only mouse input and does not interfere with ACAD in any other way. There is something tricky about Dynamic Input implementation (2006), and I'm suspecting it's related to "TextBox" input control.
Now, have you ever seen a "tooltip" that gains a focus over it's parent? 🙂 That's exactly what DYN does. This is "no good" and I would never go down that path myself. Instead, I would make a "fake" input control tied to ACAD's keyboard hook, an exact replica of a classic TextBox (cursor blinking, etc.) if that was the point.
Maksim Sestic
"Tony Tanzillo" wrote in message news:5247848@discussion.autodesk.com...
Hi everyone,
Maksim Sestic
You're aboslutely right, the dialog I'm displaying is definately modeless
I was trying to place a handy windows hook to monitor certain activites
during DYN mode. Still, I found nothing new and it definately crashes ACAD
if DYNMODE > 1 while my modeless window is visible, and I guess it's
something related to how ACAD processes certain operations. After hours of
trying I kind of narrowed source of error to the point when ACAD gets to
display an Arc/Circle jig (?!?), but this sounds so insane that I just quit
experimenting further.
Experiment results (modeless window is visible, DYN mode status is
irrelevant):
ACAD2006, .NET 2.0, VS.NET 2005
1) user draws a line/pline/whatever - just not an arc/circle: everything's
fine
2) user draws an arc/circle - standard jig lines of arc/circle are
invisible, when diameter is confirmed ACAD crashes
3) DYN input boxes work fine, crashes when DYN tries to draw a helper arc
(see 2)
Maksim Sestic
news:5248769@discussion.autodesk.com...
in any other way. "
Maksim Sestic
Hi everyone,
Maksim Sestic
”Boost
