.NET
Active Contributor
gulzar25
Message 1 of 9 (349 Views)
Accepted Solution
Point on line
349 Views, 8 Replies
07-09-2013 04:52 AM
Is there any function available to find out if a point is present on a line or not?Please help.
Gulzar
if your problem is not solved yet , you can go through this article. I hope this will solve your problem.
http://through-the-interface.typepad.com/through_the_interface/2012/01/testing-whether-a-point-is-on-an-autocad-polyline-using-net.html
Regards
Zakir
Moderator
Alexander.Rivilis
Message 2 of 9 (343 Views)
Re: Point on line
07-09-2013 05:47 AM in reply to: gulzar25
Point3d p; // Given point
Curve crv; // Given curve, eg. Line, Polyline, Circle, etc...
Point3d pNear = crv.GetClosestPointTo(p);
if (pNear.DistanceTo(p) < Tolerance.Global.EqualPoint)
  // Point is on Curve
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Active Contributor
gulzar25
Message 3 of 9 (298 Views)
Re: Point on line
07-09-2013 08:57 PM in reply to: gulzar25
Hi Alexander,
Thankyou so much for the reply but if i declare pNear as Point3d, GetClosestPointTo() function doesnt accept as it returns PointOnCurve3d and if i declare pNear as Point3d i cant access DistanceTo() function.Kindly help.
Gulzar
Moderator
Alexander.Rivilis
Message 4 of 9 (290 Views)
Re: Point on line
07-09-2013 10:39 PM in reply to: gulzar25
using System;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
[assemblyCommandClass(typeof(Rivilis.CurveUtils))]
namespace Rivilis
  public class CurveUtils
    [CommandMethod("PointOnCurve")]
    public void MyCommand() // This method can have any name
      Document doc = Application.DocumentManager.MdiActiveDocument;
      Editor ed = doc.Editor;
      PromptEntityOptions peOpt = new PromptEntityOptions("\nSelect curve: ");
      peOpt.SetRejectMessage("\nMust be Curve!");  peOpt.AddAllowedClass(typeof(Curve), false);
      PromptEntityResult peRes = ed.GetEntity(peOpt);
      if (peRes.Status != PromptStatus.OK) return;
      PromptPointResult ppRes = ed.GetPoint("\bPick point: ");
      if (ppRes.Status != PromptStatus.OK) return;
      Point3d p = ppRes.Value.TransformBy(ed.CurrentUserCoordinateSystem);
      using (Transaction tr = doc.TransactionManager.StartTransaction()) {
        Curve crv = tr.GetObject(peRes.ObjectId, OpenMode.ForRead) as Curve;
        if (crv != null) {
          Point3d pNear = crv.GetClosestPointTo(p, false);
          if (pNear.DistanceTo(p) < Tolerance.Global.EqualPoint) {
            ed.WriteMessage("\nPoint is on Curve");
          } else {
            ed.WriteMessage("\nPoint is not on Curve");
Active Contributor
gulzar25
Message 5 of 9 (290 Views)
Re: Point on line
07-09-2013 10:39 PM in reply to: Alexander.Rivilis
If i have 2 points on the same line the code is working fine for 1 point and for the other point it is not satisfying the condition ("if (pNear.DistanceTo(p) < Tolerance.Global.EqualPoint)") even though the second point is on the given line.I am not able to figure out why this is happening.I will be grateful for replies.
Thanks Gulzar
Moderator
Alexander.Rivilis
Message 6 of 9 (277 Views)
Re: Point on line
07-10-2013 12:27 AM in reply to: gulzar25
Ok! You can replace in code Tolerance.Global.EqualPoint with 0.001 (or other small value).
Active Contributor
gulzar25
Message 7 of 9 (272 Views)
Re: Point on line
07-10-2013 12:35 AM in reply to: Alexander.Rivilis
Hi Alexander,
Thanks for the reply.What i meant when i said that it is not satisfying the condition ("(pNear.DistanceTo(p) < Tolerance.Global.EqualPoint)") is distance is coming greater than tolerance value(for example 100).Even though the point is on the line for which im checking.I dont know why this is happening.
Gulzar
Moderator
Alexander.Rivilis
Message 8 of 9 (263 Views)
Re: Point on line
07-10-2013 01:58 AM in reply to: gulzar25
I think the line and a point are in 3D. Double check the coordinates of the given point and the nearest point on the line.
mzakiralam
Message 9 of 9 (236 Views)
Re: Point on line
07-11-2013 07:33 AM in reply to: gulzar25
http://through-the-interface.typepad.com/through_the_interface/2012/01/testing-whether-a-point-is-on...
Regards
Zakir
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
