.NET
Active Contributor
gulzar25
Message 1 of 9 (336 Views)
Point on line
336 Views, 8 Replies
07-09-2013 04:52 AM
Is there any function available to find out if a point is present on a line or not?Please help.
Gulzar
if your problem is not solved yet , you can go through this article. I hope this will solve your problem.
http://through-the-interface.typepad.com/through_the_interface/2012/01/testing-whether-a-point-is-on-an-autocad-polyline-using-net.html
Regards
Zakir
Moderator
Alexander.Rivilis
Message 2 of 9 (330 Views)
Re: Point on line
07-09-2013 05:47 AM in reply to: gulzar25
Point3d p; // Given point
Curve crv; // Given curve, eg. Line, Polyline, Circle, etc...
Point3d pNear = crv.GetClosestPointTo(p);
if (pNear.DistanceTo(p) < Tolerance.Global.EqualPoint)
  // Point is on Curve
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Active Contributor
gulzar25
Message 3 of 9 (285 Views)
Re: Point on line
07-09-2013 08:57 PM in reply to: gulzar25
Hi Alexander,
Thankyou so much for the reply but if i declare pNear as Point3d, GetClosestPointTo() function doesnt accept as it returns PointOnCurve3d and if i declare pNear as Point3d i cant access DistanceTo() function.Kindly help.
Gulzar
Moderator
Alexander.Rivilis
Message 4 of 9 (277 Views)
Re: Point on line
07-09-2013 10:39 PM in reply to: gulzar25
using System;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
[assemblyCommandClass(typeof(Rivilis.CurveUtils))]
namespace Rivilis
  public class CurveUtils
    [CommandMethod("PointOnCurve")]
    public void MyCommand() // This method can have any name
      Document doc = Application.DocumentManager.MdiActiveDocument;
      Editor ed = doc.Editor;
      PromptEntityOptions peOpt = new PromptEntityOptions("\nSelect curve: ");
      peOpt.SetRejectMessage("\nMust be Curve!");  peOpt.AddAllowedClass(typeof(Curve), false);
      PromptEntityResult peRes = ed.GetEntity(peOpt);
      if (peRes.Status != PromptStatus.OK) return;
      PromptPointResult ppRes = ed.GetPoint("\bPick point: ");
      if (ppRes.Status != PromptStatus.OK) return;
      Point3d p = ppRes.Value.TransformBy(ed.CurrentUserCoordinateSystem);
      using (Transaction tr = doc.TransactionManager.StartTransaction()) {
        Curve crv = tr.GetObject(peRes.ObjectId, OpenMode.ForRead) as Curve;
        if (crv != null) {
          Point3d pNear = crv.GetClosestPointTo(p, false);
          if (pNear.DistanceTo(p) < Tolerance.Global.EqualPoint) {
            ed.WriteMessage("\nPoint is on Curve");
          } else {
            ed.WriteMessage("\nPoint is not on Curve");
Active Contributor
gulzar25
Message 5 of 9 (277 Views)
Re: Point on line
07-09-2013 10:39 PM in reply to: Alexander.Rivilis
If i have 2 points on the same line the code is working fine for 1 point and for the other point it is not satisfying the condition ("if (pNear.DistanceTo(p) < Tolerance.Global.EqualPoint)") even though the second point is on the given line.I am not able to figure out why this is happening.I will be grateful for replies.
Thanks Gulzar
Moderator
Alexander.Rivilis
Message 6 of 9 (264 Views)
Re: Point on line
07-10-2013 12:27 AM in reply to: gulzar25
Ok! You can replace in code Tolerance.Global.EqualPoint with 0.001 (or other small value).
Active Contributor
gulzar25
Message 7 of 9 (259 Views)
Re: Point on line
07-10-2013 12:35 AM in reply to: Alexander.Rivilis
Hi Alexander,
Thanks for the reply.What i meant when i said that it is not satisfying the condition ("(pNear.DistanceTo(p) < Tolerance.Global.EqualPoint)") is distance is coming greater than tolerance value(for example 100).Even though the point is on the line for which im checking.I dont know why this is happening.
Gulzar
Moderator
Alexander.Rivilis
Message 8 of 9 (250 Views)
Re: Point on line
07-10-2013 01:58 AM in reply to: gulzar25
I think the line and a point are in 3D. Double check the coordinates of the given point and the nearest point on the line.
mzakiralam
Message 9 of 9 (223 Views)
Re: Point on line
07-11-2013 07:33 AM in reply to: gulzar25
http://through-the-interface.typepad.com/through_the_interface/2012/01/testing-whether-a-point-is-on...
Regards
Zakir
