.NET
jgarciaanton
Message 1 of 2 (111 Views)
Point entity ?
111 Views, 1 Replies
10-11-2006 07:16 AM
I need to do something very simple but I am having problems with it.
I need to add a point to the model space, the same way that I can add a circle or another entity. The problem is that if I get a point from the editor I can not add it the normal way, because it doesn´t inherit from the Autodesk.AutoCAD.DatabaseServices.Entity class. I have also tried to use CType with no luck.
There is a class called PointEntity2d but I cannot see a way of creating an object from it and assign it a point2d.
I am using Acad2007 and VS 2005.
If anyone could "point" me in the right direction...
Thanks in advance
j.
Distinguished Contributor
jbooth
Message 2 of 2 (111 Views)
Re: Point entity ?
10-11-2006 07:40 AM in reply to: jgarciaanton
Use the PointEntity2d or PointEntity3d classes, instead of Point2d and Point3d. The latter is not intended to be added to the database by itself - it is used to do other things (ex: specify block insertion points).
Announcements
Need installation help?
