.NET
.NET
Robert_Fritz
Message 1 of 2 (141 Views)
Plugin > AC crashes when starting second instance
141 Views, 1 Replies
07-08-2013 06:32 AM
I have written a little plugin for AC (Map). Works fine when I start up AC once.But when I start up AC a second time (whilest first instance is still running) the newly started instance of AC crashes with an unhandled excpetion.
The only difference between other plugins I have written and this one is that it loads a third party dll (avalonedit - wpf based texteditor). To me it looks like the dll a loaded twice and somehow causes the crash. Could that be the reason? Can anyone point to further information on this? I'm not an expert programmer - so I'm not sure if I do something obvious wrong.
Many thanks, Rob
AC (Map) 2013, Sp2.
http://raumpatrouille3d.blogspot.ch/
Robert_Fritz
Message 2 of 2 (104 Views)
Re: Plugin > AC crashes when starting second instance
07-09-2013 10:54 PM in reply to: Robert_Fritz
issue seems to be related to SP2. SP2 is faulty and was pulled back by ADSK.
After applying a workaround as described here the issue went away:
http://forums.autodesk.com/t5/AutoCAD-Map-3D/Map3D-2013-Service-Pack-2-Warning/td-p/4310593
Rob
