.NET
Plugin, Autoloader and Help-files
3 REPLIES 3
hence_the_name
805 Views, 3 Replies
with any plugin you can provide a help file as well which needs to be specified in packagecontents.xml, e.g.:
HelpFile="./Contents/maplayereditor.htm"
Unfortunately it doesn't work for me - when I place the cursor on my plug-in icon in the ribbon and press F1 I just end up at
http://docs.autodesk.com/errors/404.htm
How is the help system for plugins supposed to work? Has anyone successfully used the help system?
I have AC Map 2013 Sp2,
Many thanks, Rob
http://raumpatrouille3d.blogspot.ch/
3 REPLIES 3
It should work...
Make sure the relative path is correct (from the PackageContent.xml) and you have specified the AppNameSpace="appstore.exchange.autodesk.com"
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
I tried different paths but none worked.
Examples:
help file in same folder as packagecontents:
HelpFile="./maplayereditor.htm"
HelpFile="maplayereditor.htm"
I put the file in subfolders as well and set the path - to no avail.
Not sure about the "appnamespace":
AppNameSpace (optional) : This is an additional app namespace string, it is currently only used by the Autodesk AppManager to indicate Autodesk specific products.
I don't want to put anything on appstore. Why is it required for the help system?
Anyway - is my assumption correct that the htm file I have configured in packagecontext.xml should be displayed in a browser when I press "F1" whilst hovering the mouse over my plugin button in the ribbon?
Is anything else required to configure the help system correctly? Just the html file in the right folder and path set in the xml file?
Rob
Your original path was correct - it relates to the bundle folder/Contents/Resources/MyHelpFile
This helpfile (localizable) is the quick start guide for your app, it is accessable :
1) At the end of the AppStore installer
2) The first time the App loads inside of AutoCAD, a tooltip will appear informing of the load status with a link to your app's quick start
Pressing F1 on a Ribbon, is a whole different system which is documented elsewhere - it's currently not supported directly by the autoloader
Fenton Webb
AutoCAD Engineering
”Boost
