Hi!
I'm trying to plot a two-page document to PDF and DWF.
The first page should be plotted from model-space, the second page should be
plotted from a paper-space layout I create earlier with
LayoutManager.Current.CreateLayout(name).
Creating the layout works just fine, as well as printing the first page.
When it comes to print the second page, I run into errors.
The line "infoValidatorLegende.Validate(infoLegende);" throws an exception
"eLayoutNotCurrent".
The current layout when I run "Exportieren" is the model-space.
I wouldn't mind setting the paper-space layout to the current layout, but it
doesn't work.
When I try to set the layout to current using
LayoutManager.Current.CurrentLayout = legendeLayoutName;
I get another exception complaining about illegally writing to protected
memory.
Below you'll find my code that does the plotting.
Can anyone please help me?
I need to get this fixed quickly.
Best Regards
Christian Nitschkowski
public void Exportieren(Document dokument, string dateiName, string
plotterName, bool istQuerformat, string legendeLayoutName)
Database db = dokument.Database;
Transaction trans = db.TransactionManager.StartTransaction();
try
DBDictionary layoutDict =
(DBDictionary)trans.GetObject(db.LayoutDictionaryId,
Autodesk.AutoCAD.DatabaseServices.OpenMode.ForRead);
PlotInfo infoModell = new PlotInfo();
PlotInfo infoLegende = null;
LayoutManager lMan = LayoutManager.Current;
// Hier wird das Modell-Layout zum Plotten gewählt
BlockTable bt =
(BlockTable)trans.GetObject(db.BlockTableId,
BlockTableRecord btrModell =
(BlockTableRecord)trans.GetObject(bt[BlockTableRecord.ModelSpace],
infoModell.Layout = btrModell.LayoutId;
if (legendeLayoutName.Length > 0)
infoLegende = new PlotInfo();
infoLegende.Layout =
lMan.GetLayoutId(legendeLayoutName);
// Setze Settings für den Modellbereich
PlotSettings plotSettingsModell = new PlotSettings(true);
PlotSettingsValidator settingsValidator =
PlotSettingsValidator.Current;
settingsValidator.SetPlotConfigurationName(plotSettingsModell,
plotterName, _plotStilName);
settingsValidator.RefreshLists(plotSettingsModell);
settingsValidator.SetPlotCentered(plotSettingsModell, true);
settingsValidator.SetPlotType(plotSettingsModell,
Autodesk.AutoCAD.DatabaseServices.PlotType.Extents);
if (istQuerformat)
settingsValidator.SetPlotRotation(plotSettingsModell,
PlotRotation.Degrees090);
else
PlotRotation.Degrees000);
infoModell.OverrideSettings = plotSettingsModell;
// Setze Settings für den Papierbereich "Legende"
if (infoLegende != null)
PlotSettings plotSettingsLegende = new
PlotSettings(false);
settingsValidator.SetPlotConfigurationName(plotSettingsLegende,
settingsValidator.SetPlotType(plotSettingsLegende,
Autodesk.AutoCAD.DatabaseServices.PlotType.Layout);
infoLegende.OverrideSettings = plotSettingsLegende;
PlotInfoValidator infoValidatorModell = new
PlotInfoValidator();
infoValidatorModell.Validate(infoModell);
PlotInfoValidator infoValidatorLegende = new
PlotProgressDialog dialog = new PlotProgressDialog(false, 1,
true);
dialog.set_PlotMsgString(PlotMessageIndex.DialogTitle,
"Plotte ...");
dialog.set_PlotMsgString(PlotMessageIndex.CancelJobButtonMessage,
"Plot abbrechen");
dialog.set_PlotMsgString(PlotMessageIndex.CancelSheetButtonMessage,
"Seite abbrechen");
dialog.set_PlotMsgString(PlotMessageIndex.SheetSetProgressCaption,
"Fortschritt Plott");
dialog.set_PlotMsgString(PlotMessageIndex.SheetProgressCaption,
"Fortschritt Seite");
dialog.LowerPlotProgressRange = 0;
dialog.UpperPlotProgressRange = 100;
dialog.IsVisible = true;
PlotPageInfo pageInfo = new PlotPageInfo();
PlotPageInfo pageInfoLegende = new PlotPageInfo();
Object parms = null;
PlotEngine engine = PlotFactory.CreatePublishEngine();
engine.BeginPlot(dialog, parms);
engine.BeginDocument(infoModell, dokument.Name, parms, 1,
true, dateiName);
engine.BeginPage(pageInfo, infoModell, false, parms);
engine.BeginGenerateGraphics(parms);
engine.EndGenerateGraphics(parms);
engine.EndPage(parms);
engine.BeginPage(pageInfoLegende, infoLegende, true,
parms);
engine.EndDocument(parms);
engine.EndPlot(parms);
engine.Destroy();
engine = null;
dialog.Destroy();
catch (System.Exception ex)
throw new BearbeitungException(BearbeitenFehler.Export,
string.Format("Fehler beim Export in Datei {0}", dateiName), ex);
finally
trans.Dispose();
