.NET
Plotting in vb.net
1 REPLY 1
473 Views, 1 Reply
Plotting in vb.net
Someone help, my plotinfo isnt validating and I dont see whats wrong!
Dim PltInf As PlotInfo = New PlotInfo()
Dim PltSetVal As PlotSettingsValidator
Dim pltSet As PlotSettings = New PlotSettings(True)
Dim PltInfVal As PlotInfoValidator = New PlotInfoValidator()
Dim plotEng As PlotEngine = PlotFactory.CreatePublishEngine
Dim plotDialog As PlotProgressDialog = New PlotProgressDialog(False, 1, False)
For i = ActionList.Items.Count - 1 To 0 Step -1
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.Open(ActionList.Items.Item(i), True)
'progress meter
pubPage.PrintProgress.Value = ((ActionList.Items.Count * 100) - (i * 100))
pubPage.PrintVal.Text = i
'Set plot config
pltSet = New PlotSettings(True)
PltSetVal = PlotSettingsValidator.Current
PltInf.Layout = LayoutManager.Current.GetLayoutId("model")
PltSetVal.SetPlotConfigurationName(pltSet, lines(8), lines(9))
PltSetVal.SetPlotPaperUnits(pltSet, PlotPaperUnit.Millimeters)
PltSetVal.SetPlotRotation(pltSet, PlotRotation.Degrees090)
PltSetVal.SetPlotType(pltSet, Autodesk.AutoCAD.DatabaseServices.PlotType.Extents)
PltSetVal.SetPlotCentered(pltSet, True)
PltSetVal.SetCurrentStyleSheet(pltSet, lines(11))
PltSetVal.SetCanonicalMediaName(pltSet, lines(9))
PltInf.OverrideSettings = pltSet
PltSetVal = Nothing
PltInfVal.Validate(PltInf)
MsgBox("Validated:" & PltInf.IsValidated)
If plotEng IsNot Nothing Then
plotDialog.IsVisible = True
plotDialog.OnBeginPlot()
plotEng.BeginPlot(plotDialog, Nothing)
plotEng.BeginDocument(PltInf, ActionList.Items.Item(i), Nothing, lines(10), False, Nothing)
Dim pageinfo As PlotPageInfo = New PlotPageInfo()
plotDialog.OnBeginSheet()
plotEng.BeginPage(pageinfo, PltInf, True, Nothing)
plotEng.BeginGenerateGraphics(Nothing)
plotEng.EndGenerateGraphics(Nothing)
plotEng.EndPage(Nothing)
'plotDialog.OnEndSheet()
plotEng.EndDocument(Nothing)
plotEng.EndPlot(Nothing)
plotDialog.OnEndPlot()
pltSet.Dispose()
PltInfVal.Dispose()
PltInf.Dispose()
plotDialog.Dispose()
plotEng.Dispose()
Next
1 REPLY 1
As normal, I went away and came back to this and managed to find the answer. Line 4 of my code specifies modelspace, you just need to change the value to false.
”Boost
