.NET
Amremad
Message 1 of 12 (1,037 Views)
Plotting Device Information with events
1037 Views, 11 Replies
04-23-2013 04:40 AM
hi
how can i catch the plotting information (paper size and scale ... ) using plotting device??
I was on vacation for a while. So, this reply might be a late. But here it goes anyway.
Have you looked at Autodesk.AutoCAD.PlottingServices.PlotReactorManager class?
It raises events when AutoCAD plots: Begin/EndPlot, Begin/EndDocument, BeginEndPage... I am not sure what "Plot" event Balaji was referring to, but PlotReactorManager class provides all information you need to know (copies of plot, paper size, plot device name...via BeginPlot/Document/PageEventArgs.
So, simply get an instance of PlotReactorManager and handle the events raised by it, you'll get all the information whan AutoCAD plots. Specifically, if you need to know paper size, you need to handle BeginPage, and the BeginPageEventArgs has a property "PlotInfo", which intern has a property "ValidatedSettings" (type of PlotSettings), from which you can get the information of paper size, scale...
I posted an article a couple of years ago that might be of help to you:
http://drive-cad-with-code.blogspot.ca/2011_02_01_archive.html
khoa.ho
Message 2 of 12 (1,018 Views)
Re: Plotting Device Information with events
04-23-2013 08:22 AM in reply to: Amremad
Try to use PlotSettings, PlotSettingsValidator. AutoCAD DevBlog will give you a hint at this link.
-Khoa
www.netscriptcad.com
Amremad
Message 3 of 12 (983 Views)
04-28-2013 12:40 AM in reply to: khoa.ho
no no no
i need to know when user plote
whate the device and paper size and other plotting information
ADN Support Specialist
Balaji_Ram
Message 4 of 12 (949 Views)
05-02-2013 05:29 AM in reply to: Amremad
The Plot event does not provide such information.
It is limited to what the "BeginPlotEventArgs" class provides.
Balaji
Developer Technical Services
Autodesk Developer Network
norman.yuan
Message 5 of 12 (927 Views)
05-06-2013 03:07 AM in reply to: Amremad
Balaji_Ram
Message 6 of 12 (921 Views)
05-06-2013 04:37 AM in reply to: Amremad
Sorry, I did not pay attention to the "BeginPageEventArgs" class.
Thanks to Norman for correcting me and the link to his nice blog post.
Balaji
Amremad
Message 7 of 12 (898 Views)
05-07-2013 01:37 AM in reply to: norman.yuan
Imports Autodesk.AutoCAD.PlottingServices
Public Class AMRLISP
    Dim WithEvents PlotManager As PlotReactorManager
    Private Sub PlotManager_BeginPlot(sender As Object, e As BeginPlotEventArgs) Handles PlotManager.BeginPlot
        MsgBox("BeginPlot")
    End Sub
End Class
 thankyou Mr. norman.yuan
can help me with above code?? plz
the message doesn't appear  ... Why ??
Balaji_Ram
Message 8 of 12 (893 Views)
05-07-2013 01:51 AM in reply to: Amremad
Can you try this ?
    Public Sub InitializePlotEvents()
        mPlotReactorManager = New PlotReactorManager()
        AddHandler mPlotReactorManager.BeginPlot, AddressOf BeginPlot
        AddHandler mPlotReactorManager.EndPlot, AddressOf EndPlot
    End Sub
    Private Sub BeginPlot(ByVal sender As Object, ByVal e As Autodesk.AutoCAD.PlottingServices.BeginPlotEventArgs)
        WriteMessage("BeginPlot")
    End Sub
    Private Sub EndPlot(ByVal sender As Object, ByVal e As Autodesk.AutoCAD.PlottingServices.EndPlotEventArgs)
        WriteMessage("EndPlot")
    End Sub
 Edit :
Also remember to set the "BACKGROUNDPLOT” system variable to 0.
Balaji
Amremad
Message 9 of 12 (889 Views)
05-07-2013 01:58 AM in reply to: Balaji_Ram
i need to use events not delegates
i know this way but i need to use the events , but i don't know what can i write in Initialize Method to run my events
Amremad
Message 10 of 12 (887 Views)
05-07-2013 02:01 AM in reply to: Amremad
i solve it
i wort  in Initialize Method
PlotManager = New  PlotReactorManager
