.NET
Plotting Device Information with events
11 REPLIES 11
Message 1 of 12
Amremad
1429 Views, 11 Replies
hi
how can i catch the plotting information (paper size and scale ... ) using plotting device??
11 REPLIES 11
Message 2 of 12
khoa.ho
in reply to: Amremad
Try to use PlotSettings, PlotSettingsValidator. AutoCAD DevBlog will give you a hint at this link.
-Khoa
www.netscriptcad.com
Message 3 of 12
Amremad
in reply to: khoa.ho
no no no
i need to know when user plote
whate the device and paper size and other plotting information
Message 4 of 12
Balaji_Ram
The Plot event does not provide such information.
It is limited to what the "BeginPlotEventArgs" class provides.
Balaji
Developer Technical Services
Autodesk Developer Network
Message 5 of 12
norman.yuan
I was on vacation for a while. So, this reply might be a late. But here it goes anyway.
Have you looked at Autodesk.AutoCAD.PlottingServices.PlotReactorManager class?
It raises events when AutoCAD plots: Begin/EndPlot, Begin/EndDocument, BeginEndPage... I am not sure what "Plot" event Balaji was referring to, but PlotReactorManager class provides all information you need to know (copies of plot, paper size, plot device name...via BeginPlot/Document/PageEventArgs.
So, simply get an instance of PlotReactorManager and handle the events raised by it, you'll get all the information whan AutoCAD plots. Specifically, if you need to know paper size, you need to handle BeginPage, and the BeginPageEventArgs has a property "PlotInfo", which intern has a property "ValidatedSettings" (type of PlotSettings), from which you can get the information of paper size, scale...
I posted an article a couple of years ago that might be of help to you:
http://drive-cad-with-code.blogspot.ca/2011_02_01_archive.html
Message 6 of 12
Balaji_Ram
Sorry, I did not pay attention to the "BeginPageEventArgs" class.
Thanks to Norman for correcting me and the link to his nice blog post.
Balaji
Message 7 of 12
Amremad
in reply to: norman.yuan
Imports Autodesk.AutoCAD.PlottingServices
Public Class AMRLISP
    Dim WithEvents PlotManager As PlotReactorManager
    Private Sub PlotManager_BeginPlot(sender As Object, e As BeginPlotEventArgs) Handles PlotManager.BeginPlot
        MsgBox("BeginPlot")
    End Sub
End Class
 thankyou Mr. norman.yuan
can help me with above code?? plz
the message doesn't appear  ... Why ??
Message 8 of 12
Balaji_Ram
Can you try this ?
    Public Sub InitializePlotEvents()
        mPlotReactorManager = New PlotReactorManager()
        AddHandler mPlotReactorManager.BeginPlot, AddressOf BeginPlot
        AddHandler mPlotReactorManager.EndPlot, AddressOf EndPlot
    End Sub
    Private Sub BeginPlot(ByVal sender As Object, ByVal e As Autodesk.AutoCAD.PlottingServices.BeginPlotEventArgs)
        WriteMessage("BeginPlot")
    End Sub
    Private Sub EndPlot(ByVal sender As Object, ByVal e As Autodesk.AutoCAD.PlottingServices.EndPlotEventArgs)
        WriteMessage("EndPlot")
    End Sub
 Edit :
Also remember to set the "BACKGROUNDPLOT” system variable to 0.
Balaji
Message 9 of 12
Amremad
in reply to: Balaji_Ram
i need to use events not delegates
i know this way but i need to use the events , but i don't know what can i write in Initialize Method to run my events
Message 10 of 12
Amremad
i solve it
i wort  in Initialize Method
PlotManager = New  PlotReactorManager
Message 11 of 12
Amremad
it's work good
but i have two think can't catch it
1- Scale
2- which layout printed
Message 12 of 12
norman.yuan
As my previous reply pointed out: in the BeginPage event handler, the BeginPageEventArgs provides the information you need.
The code would be like:
void MyPlotReactorManager_BeginPage(object sender, BeginPageEventArgs e)
    //Get Layout name the current plotted page is plotting
    PlotInfo pInfo=e.PoltInfo;
    ObjectId layoutId=pInfo.Layout;
    //Then, you can open a transaction to get Layout object, hence, its name
    //Get scale, depending on whether standard or custom scale is used
    PlotSettings pSettings=pInfo.ValidatedSettings;
    CustomScale scale=pSetting.CustomPrintScale;
    //or
    double stdScale=pSetting.StdScale
   //Paper size
   Point2d size=pSettiings.PlotPaperSize
Note, the code is just off my head and not tested, but you get the idea: just digging into BeginPageEventArgs's PlotInfo property would get all information you need.
”Boost
