.NET
.NET
Active Member
1 Kudo
Post 1 of 11
PlotSettingsValidator, SetStdScale Error
364 Views, 10 Replies
05-07-2012 10:16 AM
Have a WPF form to input ploting parameters, all of which is typical to plotting in AutoCAD Select Scale (Custom or 1:1, 1:2, 2:1,1/128 - 1'-0" etc...).  Have a special request for a 1:2.1 value for a non-typical output device (which works just fine in the AutoCAD plot dialog and as 0.4762 : 1 Input into Inches and Units variables).  This value bombs my program with a 'Conversion from string "Error occured" to type 'Integer' is not valid' Error inside a try catch block.
Have tried several things and I'm petty sure I'm setting all 'PlotSettingsValidator' object settings correctly.  So far nothing helps.
Entire procedure is included below (program bombs at: psv.SetStdScale(pltsettings, sc))
Any help you could offer would be highly valued.
CODE
 Sub Plot(ByVal doc As Document, ByVal CurrLayout As Layout, _
  ByVal Stamp As Boolean, ByVal StampFileName As String, _
              ByVal plot2file As Boolean, Optional ByVal fname As String = Nothing)
        Try
            Dim tr As Transaction = _
  Application.DocumentManager.MdiActiveDocument.TransactionManager._
  StartTransaction
            Try
                If fname = "" Then fname = Nothing
                Dim layoutMgr As LayoutManager = LayoutManager.Current, sc As Double
                layoutMgr.CurrentLayout = CurrLayout.LayoutName
                If Stamp Then
                    InsertBlock(doc.Database, StampFileName, "CONFIDENTIAL", False, 0, _
    New Point3d(0, 0, 0))
                End If
                doc.SendStringToExecute("Zoom" & vbCr & "e" & vbCr, True, False, False)
                Dim pltsettings As New PlotSettings(CurrLayout.ModelType)
                pltsettings.CopyFrom(CurrLayout)
                pltsettings.ScaleLineweights = bplot.ScaleLW.IsChecked
                Dim pltinfo As New PlotInfo
                pltinfo.Layout = CurrLayout.Id
                Dim psv As PlotSettingsValidator = PlotSettingsValidator.Current
                psv.SetPlotConfigurationName(pltsettings, bplot.PlotterCB.SelectedItem, _
   bplot.SizeCB.SelectedItem.tag)
                psv.SetCurrentStyleSheet(pltsettings, bplot.Penstyle_CB.SelectedItem)
                psv.SetPlotPaperUnits(pltsettings, PlotPaperUnit.Inches)
                psv.RefreshLists(pltsettings)
                psv.SetPlotType(pltsettings, _
   ConvertPlotType(bplot.TypeCB.SelectedItem.content))
                psv.SetUseStandardScale(pltsettings, True)
                psv.SetPlotRotation(pltsettings, _
   ConvertPlotOrientation(bplot.RotationCB.SelectedItem.content, _
   bplot.UpsideDownChk.IsChecked))
                psv.SetPlotCentered(pltsettings, bplot.CenterPlot.IsChecked)
                'Conversion from string "NA" to type 'Double' is not Valid.
                'Conversion from string "Error occured" to type 'Integer' is not valid.
                If bplot.Scale2Fit.IsChecked Then
                    psv.SetStdScaleType(pltsettings, StdScaleType.ScaleToFit)
                Else
                    If bplot.ScaleB.Text = "N/A" Then
                        MsgBox("Plot 1. . .")
                        sc = CDbl(bplot.ScaleA.Text)
                    Else
                        MsgBox("Plot 2. . .")
                        Dim inchval, unitval As Double
                        inchval = CDbl(bplot.ScaleA.Text)
   unitval = CDbl(bplot.ScaleB.Text)
                        MsgBox("Scalea.text = " & inchval.ToString & " Type = " & _
    inchval.GetType.ToString & vbLf &  "Scaleb.text = " & _
    unitval.ToString & " Type = " & unitval.GetType.ToString)
                        sc = (inchval / unitval)
                    End If
                    MsgBox("Plot 2a. . .sc =" & sc.ToString)
                    MsgBox("Plot 2b. . .")
                End If
                pltinfo.OverrideSettings = pltsettings
                Dim pltprgdlg As New PlotProgressDialog(False, 1, True)
                pltprgdlg.UpperPlotProgressRange = 100
                pltprgdlg.LowerPlotProgressRange = 0
                Dim plteng As PlotEngine = PlotFactory.CreatePublishEngine
                MsgBox("Plot 3. . .")
                Try
                    MsgBox("Plot 4. . .")
                    pltprgdlg.OnBeginPlot()
                    pltprgdlg.IsVisible = True
                    plteng.BeginPlot(Nothing, Nothing)
                    Dim validator As New PlotInfoValidator
                    validator.MediaMatchingPolicy = MatchingPolicy.MatchEnabled
                    validator.Validate(pltinfo)
                    plteng.BeginDocument(pltinfo, _
   Application.DocumentManager.MdiActiveDocument.Database.Filename, _
                        Nothing, 1, plot2file, fname)
                    pltprgdlg.OnBeginSheet()
                    pltprgdlg.UpperSheetProgressRange = 100
                    pltprgdlg.LowerSheetProgressRange = 0
                    pltprgdlg.SheetProgressPos = 0
                    Dim pageinfo As New PlotPageInfo
                    plteng.BeginPage(pageinfo, pltinfo, True, Nothing)
                    plteng.BeginGenerateGraphics(Nothing)
                    plteng.EndGenerateGraphics(Nothing)
                    plteng.EndPage(Nothing)
                    pltprgdlg.SheetProgressPos = 100
                    pltprgdlg.OnEndSheet()
                    pltprgdlg.PlotProgressPos = 100
                    plteng.EndDocument(Nothing)
                    plteng.EndPlot(Nothing)
                Catch ex As Exception
                    MsgBox("Error occured in function (Plot - Inner)" & vbCr & ex.Message, _
      "Error occured")
                End Try
                pltprgdlg.Destroy()
                plteng.Destroy()
                tr.Commit()
                MsgBox("Error occured in function (Plot- Middle)" & vbCr & ex.Message, _
         "Error occured")
            Finally
                tr.Dispose()
            End Try
        Catch ex As SystemException
            System.Windows.Forms.MessageBox.Show("Error occured in function (Plot- Outer)"   & vbCr & _
                                                 "[" & ex.Message & "]", "Error occured")
            Dim pname = (New StackTrace().GetFrame(1)).GetMethod.Name
            Dim mname = (New StackFrame().GetMethod().Name)
            LogError(ex, mname, pname)
        End Try
    End Sub
Valued Mentor
30 Kudos
Post 2 of 11
Re: PlotSettingsValidator, SetStdScale Error
05-07-2012 12:29 PM in reply to: PacificorpJB
I've seen this behaviour in the editor before - eg. scaling viewports.
Try 4762 : 10000 to satisfy the integer complaint.
Active Member
1 Kudo
Post 3 of 11
05-07-2012 03:26 PM in reply to: fieldguy
Hi Fieldguy --
Thanks for the input, same thing though Im afraid (4762:10000) I think it's setstdcale call th's actually throwing the error and at that point the value is back to a decimal (0.4762...); which makes the error even more enigmatic . . .where is the interger it's refering to?
Thanks though.
Valued Mentor
30 Kudos
Post 4 of 11
05-08-2012 08:29 AM in reply to: PacificorpJB
Try this maybe.  I know it compiles and runs but I have not checked the scale on the output.
Dim myscale As CustomScale = NewCustomScale(4762, 10000)
psv.SetCustomPrintScale(ps, myscale)
0 Kudos
Post 5 of 11
05-08-2012 12:00 PM in reply to: PacificorpJB
Great, that pretty much got it with the following modifications to get it to work with all the possible values in my form.
Thanks so much for your help.
Dim psv AsPlotSettingsValidator = PlotSettingsValidator.Current
With psv
      .SetStdScaleType(pltsettings,StdScaleType.ScaleToFit)
      .SetUseStandardScale(pltsettings,True)
ElseIf bplot.ScaleB.Text = "N/A" Then
     .SetUseStandardScale(pltsettings,False)
     Dim cscale AsNew Autodesk.AutoCAD.DatabaseServices.CustomScale_
                     (CDbl(bplot.ScaleA.Text), 1.0)
     .SetCustomPrintScale(pltsettings, cscale)
Else
     Dim inchval AsDouble = CDbl(bplot.ScaleA.Text)
     Dim unitval AsDoubleCDbl(bplot.ScaleB.Text)
     Dim myscale AsNewCustomScale(inchval, unitval)
     .SetCustomPrintScale(pltsettings, myscale)
EndIf
EndIf
EndWith
Thanks Again.
Valued Mentor
30 Kudos
Post 6 of 11
05-08-2012 12:16 PM in reply to: CADKarasu
No problem - glad I could help.
Please mark the thread with an "Accepted Solution".  I think you need to do that as the creator.
0 Kudos
Post 7 of 11
05-08-2012 12:43 PM in reply to: fieldguy
Be happy to but how exactly do I go about doing that?  Poked around in all the options but couldn't find the place to do so?
Valued Mentor
30 Kudos
Post 8 of 11
05-08-2012 01:05 PM in reply to: CADKarasu
As the creator of the msg, you should see this button in all of the replies.
Active Member
1 Kudo
Post 9 of 11
05-08-2012 01:14 PM in reply to: fieldguy
Accepted Solution [cid:image001.png@01CD2D1C.5E2E76D0] Jim Brinkmeyer Systems Analyst 503 813 6615 Jim.Brinkmeyer@PacifiCorp.Com
0 Kudos
Post 10 of 11
05-08-2012 01:19 PM in reply to: CADKarasu
Hum... Except I don't.  There's nothing under the Reply link at all and I checked severl emails.  Would totally like to give you credit though.
