Imports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.EditorInput Imports Autodesk.AutoCAD.PlottingServices Imports Autodesk.AutoCAD.Geometry Imports System.Runtime.InteropServices Namespace PlottingApplication Public Class class1 <DllImport("acad.exe", CallingConvention:=CallingConvention.Cdecl, EntryPoint:="acedTrans")> _ Private Shared Function acedTrans(ByVal point As Double(), ByVal fromRb As IntPtr, ByVal toRb As IntPtr, ByVal disp As Integer, ByVal result As Double()) As Integer End Function <CommandMethod("winplot")> _ Public Shared Sub WindowPlot() Dim doc As Document = Application.DocumentManager.MdiActiveDocument Dim ed As Editor = doc.Editor Dim db As Database = doc.Database Dim ppo As New PromptPointOptions(vbLf & "Select first corner of plot area: ") ppo.AllowNone = False Dim ppr As PromptPointResult = ed.GetPoint(ppo) If ppr.Status <> PromptStatus.OK Then Return End If Dim first As Point3d = ppr.Value Dim pco As New PromptCornerOptions(vbLf & "Select second corner of plot area: ", first) ppr = ed.GetCorner(pco) If ppr.Status <> PromptStatus.OK Then Return End If Dim second As Point3d = ppr.Value ' Transform from UCS to DCS Dim rbFrom As New ResultBuffer(New TypedValue(5003, 1)), rbTo As New ResultBuffer(New TypedValue(5003, 2)) Dim firres As Double() = New Double() {0, 0, 0} Dim secres As Double() = New Double() {0, 0, 0} ' Transform the first point... acedTrans(first.ToArray(), rbFrom.UnmanagedObject, rbTo.UnmanagedObject, 0, firres) ' ... and the second acedTrans(second.ToArray(), rbFrom.UnmanagedObject, rbTo.UnmanagedObject, 0, secres) ' We can safely drop the Z-coord at this stage Dim window As New Extents2d(firres(0), firres(1), secres(0), secres(1)) Dim tr As Transaction = db.TransactionManager.StartTransaction() Using tr ' We'll be plotting the current layout Dim btr As BlockTableRecord = DirectCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForRead), BlockTableRecord) Dim lo As Layout = DirectCast(tr.GetObject(btr.LayoutId, OpenMode.ForRead), Layout) ' We need a PlotInfo object ' linked to the layout Dim pi As New PlotInfo() pi.Layout = btr.LayoutId ' We need a PlotSettings object ' based on the layout settings ' which we then customize Dim ps As New PlotSettings(lo.ModelType) ps.CopyFrom(lo) ' The PlotSettingsValidator helps ' create a valid PlotSettings object Dim psv As PlotSettingsValidator = PlotSettingsValidator.Current ' We'll plot the extents, centered and ' scaled to fit psv.SetPlotWindowArea(ps, window) psv.SetPlotType(ps, Autodesk.AutoCAD.DatabaseServices.PlotType.Window) psv.SetUseStandardScale(ps, True) psv.SetStdScaleType(ps, StdScaleType.ScaleToFit) psv.SetPlotCentered(ps, True) ' We'll use the standard DWF PC3, as ' for today we're just plotting to file psv.SetPlotConfigurationName(ps, "DWF6 ePlot.pc3", "ANSI_A_(8.50_x_11.00_Inches)") ' We need to link the PlotInfo to the ' PlotSettings and then validate it pi.OverrideSettings = ps Dim piv As New PlotInfoValidator() piv.MediaMatchingPolicy = MatchingPolicy.MatchEnabled piv.Validate(pi) ' A PlotEngine does the actual plotting ' (can also create one for Preview) If PlotFactory.ProcessPlotState = ProcessPlotState.NotPlotting Then Dim pe As PlotEngine = PlotFactory.CreatePublishEngine() Using pe ' Create a Progress Dialog to provide info ' and allow thej user to cancel Dim ppd As New PlotProgressDialog(False, 1, True) Using ppd ppd.set_PlotMsgString(PlotMessageIndex.DialogTitle, "Custom Plot Progress") ppd.set_PlotMsgString(PlotMessageIndex.CancelJobButtonMessage, "Cancel Job") ppd.set_PlotMsgString(PlotMessageIndex.CancelSheetButtonMessage, "Cancel Sheet") ppd.set_PlotMsgString(PlotMessageIndex.SheetSetProgressCaption, "Sheet Set Progress") ppd.set_PlotMsgString(PlotMessageIndex.SheetProgressCaption, "Sheet Progress") ppd.LowerPlotProgressRange = 0 ppd.UpperPlotProgressRange = 100 ppd.PlotProgressPos = 0 ' Let's start the plot, at last ppd.OnBeginPlot() ppd.IsVisible = True pe.BeginPlot(ppd, Nothing) ' We'll be plotting a single document ' Let's plot to file pe.BeginDocument(pi, doc.Name, Nothing, 1, True, "c:\test-output") ' Which contains a single sheet ppd.OnBeginSheet() ppd.LowerSheetProgressRange = 0 ppd.UpperSheetProgressRange = 100 ppd.SheetProgressPos = 0 Dim ppi As New PlotPageInfo() pe.BeginPage(ppi, pi, True, Nothing) pe.BeginGenerateGraphics(Nothing) pe.EndGenerateGraphics(Nothing) ' Finish the sheet pe.EndPage(Nothing) ppd.SheetProgressPos = 100 ppd.OnEndSheet() ' Finish the document pe.EndDocument(Nothing) ' And finish the plot ppd.PlotProgressPos = 100 ppd.OnEndPlot() pe.EndPlot(Nothing) End Using End Using Else ed.WriteMessage(vbLf & "Another plot is in progress.") End If End Using End Sub End Class End Namespace
I need to create a DLL which asks to select the required area in drawing to convert to PDF.
I have seen the smaple in Kean Walmsley site but ia m getting error near the below line,
"set_plotmsgstring is not a member of autodesk.autocad.plottingservices.plotprogressdialog"
I have added refernece of acdbmgd.dll and acmgd.
I am using VIsual sutdio 2008 and autocad 2007.
Could anyone pelase help me out from this issue?
THank you.
Where did you find the above? It should be
ppd.PlotMsgString(PlotMessageIndex.DialogTitle, "Custom Plot Progress")
You need to change this line to the pc3 file you want to use:
I suggest "DWG To PDF.pc3" for starters.
There are several examples of plot code in this forum and this: http://through-the-interface.typepad.com/through_the_interface/plotting/
Scroll down to the "Plotting a window from Autocad using .NET".
I see where you got your example from. Good work!
psv.SetPlotRotation(ps, PlotRotation.Degrees000) is landscape. Intellisense will provide the options. You probably want PlotRotation.Degrees090.
Forgot the style sheet. You can use a try/catch to make sure the CTB file is found.
psv.SetCurrentStyleSheet(ps, "CTB Filename"). "None" is represented by
psv.SetCurrentStyleSheet(ps, "")
Try
psv.SetCurrentStyleSheet(ps, ctbfile)
Catch ex AsException
'create a message or a log entry - CTB not found
'set it to none if you want
psv.SetCurrentStyleSheet(ps,"")
EndTry
Did you put setcurrentstylesheet in a try/catch? You get an explantation of what went wrong in ex.message.
You'll have to post your code - I can look it over on the weekend.
There is a mention of that issue (looks the same to me) in the comments section of this kean post: http://through-the-interface.typepad.com/through_the_interface/2007/10/previewing-and-.html
You have to scroll down to near the bottom - see the Comments from Joseph Garret. My plotting app has an "imports system.collections.specialized" statement but that was done a long time ago.
