.NET
plot points along a curve
3 REPLIES 3
gulzar25
378 Views, 3 Replies
I need ti trace 2 points (which are certain distance apart) along a curve at a distance of x inches(say 2 inches).How do i write the code such that the point is plotted on the curves and maintains the distance.Appreciate the help.
Gulzar
3 REPLIES 3
_gile
in reply to: gulzar25
Look at the Curve.GetPointAtDist() method.
Gilles Chanteau
GileCAD
GitHub
gulzar25
Hi Giles,
In Curve.GetPointAtDist(parameter).What is parameter here.Like if i give 1.0 as parameter will it return the endpoint of the line.
Gulzar
_gile
Aren't you confusing GetPointAtDist(double distance) and GetPointAtParameter(double parameter)?
Gilles Chanteau
GileCAD
GitHub
”Boost
