.NET
Plot PDF
5 REPLIES 5
amitnkukanur
1500 Views, 5 Replies
Plot PDF
I am trying to plot a PDF using COM Component and these below are the code which i used
acDoc = acApp.Documents.Open(item.SubItems[1].Text + "\\" + item.SubItems[0].Text, Type.Missing, Type.Missing);
acApp.Visible = true;
acApp.ZoomExtents();
foreach (AcadLayout layout in acDoc.Layouts)
layout.StyleSheet = "monochrome.ctb";
PtObj = acDoc.Plot;
PtConfigs = acDoc.PlotConfigurations;
PtConfigs.Add("PDF", true);
PlotConfig = PtConfigs.Item("PDF");
PlotConfig.CenterPlot = true;
PlotConfig.StandardScale = AcPlotScale.acScaleToFit;
PlotConfig.PlotType = AcPlotType.acExtents;
PlotConfig.ConfigName = "DWG To PDF.pc3";
PlotConfig.StyleSheet = "monochrome.ctb";
PlotConfig.CanonicalMediaName = "ANSI_A_(8.50_x_11.00_Inches)";
PlotConfig.PlotViewportBorders = false;
PlotConfig.PlotWithLineweights = true;
PlotConfig.PlotWithPlotStyles = true;
PlotConfig.ScaleLineweights = false;
PlotConfig.GetPlotStyleTableNames();
PlotConfig.PlotRotation = AcPlotRotation.ac90degrees;
BackPlot = acDoc.GetVariable("BACKGROUNDPLOT");
acDoc.SetVariable("BACKGROUNDPLOT", 0);
PlotConfig.RefreshPlotDeviceInfo();
if (PtObj.PlotToFile(acDoc.FullName.Replace("dwg", "pdf"), PlotConfig.ConfigName))
//Do Nothing
else
using (StreamWriter sr = newStreamWriter(FileName, true))
sr.WriteLine(acDoc.FullName.Trim());
//If you wish you can delete th plot configuration you created
//programmatically, and set the 'BACKGROUNDPLOT' system variable
//to its original status.
PtConfigs.Item("PDF").Delete();
PlotConfig = null;
acDoc.SetVariable("BACKGROUNDPLOT", BackPlot);
Even though after Giving these settings the Output PDF is not covering full sheet of paper, instead its taking a portion of paper.
Is there any way where i can solve this.
Rgds
Amit
Senior Software Engineer
5 REPLIES 5
fieldguy
in reply to: amitnkukanur
Using the managed API (2010) my plot creator has "psv.SetUseStandardScale(ps, True)"  and "psv.SetStdScaleType(ps, StdScaleType.ScaleToFit)".
ps is PlotSettings and psv is PlotSettingsValidator.  Try SetUseStandardScale(??, true) before acscaletofit.
amitnkukanur
in reply to: fieldguy
Hello FieldGuy,
Thanks for replying. Where and how will i find My Plot Creator because i am hearing it first time. If you could share a sample with me if you have.
Amit
fieldguy
amitnkukanur
Hi fieldguy,
Thanks for reply, the post helped to solve the problem to certain extent.
Thanks for a reply.
Cheers,
Amit
fieldguy
I'm glad you found the solution.
Cheers!
”Boost
