.NET
Distinguished Contributor
BillZ
Message 1 of 3 (534 Views)
plot example in C#
534 Views, 2 Replies
09-19-2005 08:49 AM
R2005:
I am looking for some code examples to plot the active document.
I was hoping to feed a file name during the process to the PDF plotter (I think it's part of the Adobe distiller).
I cannot do this with lisp or Vlisp.
I am trying to write a .dll or command that I can use to plot each layer of a drawing as I loop through them.
I have my console application set up in VS ver.7.1.3088 but am fairly new to C# type of programming.
I have done a few basic programs and tutorals and now need a shove in the right direction to do plotting.
Thanks for any constructive recommendations.
Bill
BillZ
Message 2 of 3 (534 Views)
Re: plot example in C#
09-20-2005 06:11 AM in reply to: BillZ
Am I walking a forbodden path with this question?
Or is there no information that anyone cares to share on this subject?
I did many Google searches on this.
I'm thinking it should be a command method using the Autodesk.AutoCAD.Interop.AcadPlot() and the ApplicationServices.Application.DocumentManager.MdiActiveDocument(); but am not adept enough yet to put it all together.
I'll keep trying.
Bill
BillZ
Message 3 of 3 (534 Views)
09-21-2005 11:29 AM in reply to: BillZ
Okay,
I think I've made some progress.
I've set doc to the active document and set the plotter configuration to the printer I want to print to.
I still cannot figure out where I access plotting.
Can someone tell me if I have the right resources to plot?
And if so, what part of the model do I access it from?
#region Using directives
using System;
using System.Reflection;
using System.Runtime.InteropServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Interop.Common;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.PlottingServices;
#endregion
namespace PlotLayer2PdfFile
/// Summary description for Class1.
public class PDF2FileName
[CommandMethod("PlotPDF")]
public void PDF2File()
Document doc = Application.DocumentManager.MdiActiveDocument;
Autodesk.AutoCAD.PlottingServices.PlotConfigManager.SetCurrentConfig("CutePDF Writer");
//CommandLinePrompts.Message(doc.ToString());
/// The main entry point for the application.
[STAThread]
static void Main(string[] args)
//Application.Run(new PDF2FileName());
TIA
Bill
