.NET
Keith.Brown
Message 1 of 3 (169 Views)
Pipeobjects, tooltips, and xrefs.
169 Views, 2 Replies
02-01-2012 08:20 AM
I have created code for displaying information in Autocad MEP in the tooltips for a pipeobject.  To be clear, this is the tooltip that appears when you hover over a entity.  The tooltip appears to be working as intended when I am in the drawing with the actual entity.  In this case, it is an Autocad MEP pipe object.  When I hover over pipeobjects that are in xref drawings, the tooltip doesnt work anymore and it shows the out of the box tooltips.
I am checking to see if the entity under the aperature is a pipe with the following line of code:
                    If (ent.GetType.Name.ToString = Autodesk.Aec.Building.DatabaseServices.Type.Pipe.ToString) Then
So my first guess would be that the xref pipe isnt in the current database which is why the code isnt working.  So how would find the type of entity under the aperature that doesnt care if it is in the current dwg or is a xref?
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate. Thank you!
Valued Mentor
jeff
Message 2 of 3 (166 Views)
Re: Pipeobjects, tooltips, and xrefs.
02-01-2012 08:43 AM in reply to: Keith.Brown
Maybe check if it is a BlockReference and if its BlockTableRecord IsFromExternalReference
then check nested entity
You can also find your answers @ TheSwamp
Keith.Brown
Message 3 of 3 (137 Views)
02-02-2012 07:28 AM in reply to: jeff
Just making sure I understand you correctly.  So, in addition, to checking if there is a pipe under the cursor, i should check and see if it is a xref by checking to see if it is a block reference that has a block table record equal to isfromexternalreference and then check to see if it is a pipe as a nested enitity?
What if i just temporarily continually write to the command line what is under the cursor?  That should give me an idea of what to look for?  ok, i did this and stupid me, it just said block reference.  Pretty much as you said it would.  I will investigate further and see how much farther I get.
