.NET
Personalized Error MessageBox
4 REPLIES 4
fmarcelino
222 Views, 4 Replies
I developed a personalized error messagebox in C#. In a normal WindowsApplication to catch all the possible exceptions generated by that application I need to do:
public frmMainForm()
// Required for Windows Form Designer support
InitializeComponent();
// TODO: Add any constructor code after InitializeComponent call
AppDomain.CurrentDomain.UnhandledException += new UnhandledExceptionEventHandler(MyExceptionMessageBox.Show);
Application.ThreadException += new System.Threading.ThreadExceptionEventHandler(MyExceptionMessageBox.Show);
Now, I developed a pallete to AutoCAD using C# to. My question is, how can I redirect all Exceptions generated by my application to MyExceptionMessageBox like I do in Windows Forms.
Thanks in advance for your attention,
Filipe Marcelino Message was edited by: fmarcelino
4 REPLIES 4
fmarcelino
in reply to: fmarcelino
Please help, i need a solution for this task guys...
fmarcelino
hi again,
does anyone need some kind of explanation? Am I not being clear?
Filipe Marcelino
ecarreras
Hi, did you get the problem solved? I'm trying to do the same.
JamieVJohnson
Well in VB.Net, we use Try/Catch blocks to redirect any errors to a central handler. Looks something like this...
Try
Normal use code
More normal code
Error Prone code
More normal code
Catch ex as System.Exception
HandleError(ex)
'or even this line: Dim aex as New System.Exception("Error Prone code sucks: ", ex)
'then toss the new error back out: Throw aex
'that causes the next routine up, to recieve the error, so that it can hand it off to HandleError(ex)
End Try
Then my main error handling routine HandleError(byval ex as System.Exception) takes care of the message box.
how ever, EVERY routine that starts something needs to have a try catch block to capture these errors.
jvj
”Boost
