.NET
Perpendicular Points on Polyline
3 REPLIES 3
Prajith76
1751 Views, 3 Replies
Is there is any way to get perpendicular points on both sides of a polyline at a specified distance?
I tried to offset the polyline (PL) on both directions as (PL1 & PL2) but still confused how to get a perpendicular point on PL1 & PL2 with a given point on PL.
Your inputs will be much appreciated.
Prajith.
3 REPLIES 3
joshuamodglin
in reply to: Prajith76
Prajith,
Do a search for 'Polar' points in this Forum. This should provide you the answer you are looking for.
Josh Modglin
Advanced Technologies Solutions Logo
caddzone
You can use the GetFirstDerivative() method to get the direction
of the tangent vector at a given point on the polyline, which is
at a right angle with the perpendiuclar vector.
AcadXTabs for AutoCAD
Supporting AutoCAD 2000-2011
Prajith76
Hi Friends,
Goal achieved using the below function.
  Shared Function PolarPoint(ByVal BasePoint As Point3d, ByVal angle As Double, ByVal distance As Double) As Point3d
        Dim x As Double = distance * Sin(angle)
        Dim y As Double = distance * Cos(angle)
        Return New Point3d(BasePoint.X - x, BasePoint.Y + y, BasePoint.Z)
    End Function
Hi Tony,
I am not familiar with GetFirstDerivative() method. Certainly I will look at it how it goes.
Thanks a lot.
Prajith.
”Boost
