.NET
Valued Contributor
smcclure
Message 11 of 16 (74 Views)
Re: Periscope in .NET
07-21-2006 08:39 AM in reply to: wesbird
There are two seperate questions here... First, there was a question about the PointMonitor in general... I responded with a second question about implementing the PointMonitor in ACAD2005, since it seems like the upgrade will probably take a little while here.
On a side note (although somewhat related), the .NET wrapper for the pointmanager should be basically the same between 2005 and 2006... Is the wrapper open source or would it be possible to recompile only the PointMonitor portion for 2005?
*Tony Tanzillo
Message 12 of 16 (74 Views)
07-21-2006 09:00 AM in reply to: wesbird
After looking at the 2005 managed API, yes you're
right.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
"Paul Richardson" wrote in message news:5244663@discussion.autodesk.com...
I didn't think you could monitor the cursor in 05
with managed ARX? Or did I misunderstand what
he was looking for all together.
"Tony Tanzillo" wrote in message
news:5244644@discussion.autodesk.com...
>> Same in c#. But he needs this for 2005 and as I
>> understand native ARX is the only option.
The only option for tooltips ?
*Tony Tanzillo
Message 13 of 16 (74 Views)
Paul's correct. There is no PointMonitor class in 2005's API.
No, you can't recompile it because there is no source
and it isn't nearly that simple (lot of dependence on
other APIs that are not in 2005 either).
I've said this before and I'll say it again. If you're serious
about .NET development, you need to upgrade to 2006.
Otherwise, you're not going to find much sympathy here
on how to get the benefits of the latter without ugrading.
wrote in message news:5244715@discussion.autodesk.com...
*Paul Richardson
Message 14 of 16 (74 Views)
07-21-2006 09:09 AM in reply to: wesbird
Since I was using the info you gave me, technically you're correct...:smileywink:
news:5244714@discussion.autodesk.com...
right.
*Tony Tanzillo
Message 15 of 16 (74 Views)
07-21-2006 09:12 AM in reply to: wesbird
At this juncture, with having done relatively little
work with the 2005 API, it's hard to remember what
is and is not there :-)
"Paul Richardson" wrote in message news:5244764@discussion.autodesk.com...
right.
*Paul Richardson
Message 16 of 16 (74 Views)
07-21-2006 09:55 AM in reply to: wesbird
Pointing you to this sample was meant to
highlight '
title="AcEdInputPointMonitor Class">AcEdInputPointMonitor'.
The
title="AcEdInputPointMonitor Class">tooltip part is just a
bonus.
size=2>
"Paul Richardson" <prichardsonATadelphia.net>
wrote in message
face=Arial size=2>news:5237453@discussion.autodesk.com
face=Arial size=2>...
There is a sample in
the ARX skd to do it in
C++
ObjectARX\samples\entity\MultilineTooltipSamp
<smcclure>
wrote in message
face=Arial size=2>news:5237402@discussion.autodesk.com
Is there an alternative class for AutoCAD 2005?
Unfortunately, many of the
event classes such as PointMonitor do not
exist....
