.NET
Pb Viewports with autocad mechanical 2006
1 REPLY 1
209 Views, 1 Reply
Hi, I have problem with viewport in VB.net and AutoCAD Mechanical 2006
In VB
1- I create Viewport
2- Change Viewport layer
At this point, all is ok. If I look of viewport layer, is on defpoint, I
can do regen, make modofication in paper space and is still always on
defpoints layer. But went I switch to model space and return in paper
space, the viewport layer is change to AM_VIEWS. If I create viewport with
mview command and change layer after, have no problem.
Some body can help me !!!
1 REPLY 1
chocolate_artist
Could I see your code that you use to create viewport and change viewport layer?
”Boost
