.NET
Passing parameters to command
3 REPLIES 3
656 Views, 3 Replies
I'm creating User defined command for AutoCad call 'CREATECIRCLE' and function to handle as given below
AcadApp.DocumentManager.MdiActiveDocument.SendStringToExecute("createline ",false,false,false);
which in turn call's the command function
[Autodesk.AutoCAD.Runtime.CommandMethod("CREATECIRCLE")]
public void DrawCircle()
for this, it is possible to pass parameters as such
AcadApp.DocumentManager.MdiActiveDocument.SendStringToExecute("createline gx, gy ",false,false,false);
3 REPLIES 3
sorry actual code is as like
AcadApp.DocumentManager.MdiActiveDocument.SendStringToExecute("createcircle ",false,false,false);
and it's command function is
wrote ...
> ...it is possible to pass parameters as such
> ...SendStringToExecute("createline gx, gy ",false,false,false);
I'm new at ObjectARX programming so this basically a guess:
SendStringToExecute("createline " + gxParm + ", " + gyParm +
"\n",false,false,false);
where gxParm and gyParm are member Fields/Properties within your custom
Command class.
You should include the "\n" only if the AutoCAD command processor requires
it.
Fred Chateau
"Fred Chateau" wrote ...
Command class.
It just occurred to me that your question involves sending this string to
execute your own custom command. If that is the case, you shouldn't need to
include the parameters in the string; just access the parameters as
createline class Properties and use them directly in your custom Command
method.
result = ArxMethod.BeginDraw(createline.gxParm, createline.gyParm);
Fred Chateau
”Boost
