.NET
Passing data between classes
9 REPLIES 9
Message 1 of 10
683 Views, 9 Replies
I have a command class and a form1 class associated with a form. The form
includes several textboxes. I activate the form from the command class and
enter text into the textboxes. I can then access the textbox strings within
the form1 class, but how do I access the textbox values from the command
class?
9 REPLIES 9
Message 2 of 10
AdammReilly
From within the command class, when you can use form1.[textbox1].Text
[textbox1] being whatever you named the textbox
Adam Reilly
Dell Precision 55400
Windows 10 Pro
Intel Xeon E-2276M 2.80GHz, 64bit
NVidia Quadro T2000 Mobile/Max-Q
LinkedIn | Twitter
Group Leader badge
Austin CADD User Group
LinkedIn | Discord
Message 3 of 10
Hallex
I would do by this way
Declare second form as class with arguments
See attached sample
~'J'~
Message 4 of 10
Thanks for your insight.
That's was what I thought. But I get an error that "Reference to a
non-shared member requires an object reference". I'm sure I am missing
something simple but I can;t nail it!
wrote in message news:6318347@discussion.autodesk.com...
Message 5 of 10
_gile
isn't your TextBox 'private' ? If so, set it 'internal'.
Gilles Chanteau
GileCAD
GitHub
Message 6 of 10
chiefbraincloud
you have a form. For sake of argument call it form1, with TextBox Tb1
dim txtVal as string
dim ThisForm1 as New form1
Application.ShowModalDialog(ThisForm1)
'Make sure you just hide the form in the closing event, dispose of it in the calling method
txtVal = ThisForm1.Tb1.Text
ThisForm1.Close
ThisForm1.Dispose
Doing it this way gives you the Object Reference that your error message is griping about.
(BTW, if you want a form to persist its data across multiple documents, you must declare the ThisForm1 as Shared, at the Class Level)
Message 7 of 10
The best way to deal with that problem you have is to use data binding.
When you use data binding, you define a class that serves as a container for the
data you want to show/edit, and just tell your form that you want to use the
controls on it to display/edit that data.
You can see an example of how that works (in C#), in this sample:
http://www.caddzone.com/DataBindingSample.zip
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
"Ray S Whitmore" wrote in message
news:6317990@discussion.autodesk.com...
class?
Message 8 of 10
I knew it had to be a simple solution. I added your suggested code and it
came up instantly! Now 10 more commands and 10 more forms to go.
Thanks for your help.
wrote in message news:6318516@discussion.autodesk.com...
calling method
ThisForm1.Close
ThisForm1.Dispose
griping about.
Message 9 of 10
mgorecki
Ok, so lets say you have a form (2 textboxes and a "Start" button) and a command class.  When I hit the Start button, how does the form go back to the command class to execute the functions there?  I've set it up like you describe, but I'm not sure how to make it jump from the form to the command class.  Maybe a silly question, but I'm kinda new to .Net and appreciate the help.
Mark
Message 10 of 10
norman.yuan
in reply to: mgorecki
Here is some pseudo code:
public class MyCommandClass
[CommandMethod("DoSomething")]
public static void DoWork()
  string txt1=null;
  string txt2=null;
  //Show form to get user input
  using (Form1 frm=new Form1())
    //The form is shown and the command is held until
    //the form is dismissed
    DialogResult res=Autodesk.AutoCAD.ApplicationServices.
            Application.ShowModalDialog(frm);
    //Only if the user clicks "OK/Start"
    //The user input is obtained
    if (res=DialogResult.OK)
      txt1=frm.TextValue1;
      txt2=frm.TextValue2;
  if (txt1!=null && txt2!=null)
    //Do your work with the user input acquired with the form
public class Form1:System.Windows.Forms.Form
  //Assume the form has 2 text boxes and
  //a button "Start" and a button "Cancel"
  //You add 2 public read-only properties to the form
  public string TextValue1
    get { return TextBox1.Text; }
  public string TextValue2
    get { return TextBox2.Text; }
  //You set "Start" button's DialogResult property to "OK"
  //Set "Cancel" button's DialogResult property to "Cancel"
  //So, when clicking on the buttons, the form will closed (Hidden),
  //No code is needed
 Well, you of course would do some inout validation beofre the form turns hidden.
You might wan to learn more on .NET basics on windows forms, modelss form and modal form.
Norman Yuan
Drive CAD With Code
”Boost
