.NET
.NET
tech
Message 1 of 5 (640 Views)
Pass a string with quote marks to a lisp command in VB.NET
640 Views, 4 Replies
08-10-2012 03:52 PM
I have created a string:
strAttValue = ("3/16""=1'-0""")
or alternatively I've tried:
strAttValue = ("3/16" & Chr(34) & "=1'-0" & Chr(34))
that I would like to pass to a lisp with the format:
(defun lispTest ( strAttValue / )
but when I do it errors with "Too many variables." The passing method is as follows:
acDoc.SendStringToExecute("(lispTest" & Chr(34) & strAttValue & Chr(34) & " ) ", True, False, False)
If I get rid of the quotes in the original string it works fine, but the quotes are needed. Does anyone know why this is? How can I make it work?
I really should use VB.NET or C# more often, these simple things kill me and I am sure it is something obvious! - Thanks.
BrentBurgess1980
Message 2 of 5 (606 Views)
Re: Pass a string with quote marks to a lisp command in VB.NET
08-12-2012 06:47 PM in reply to: tech
C# strAttValue = ("3/16" + "\"=1'-0\""); VB.NET strAttValue = ("3/16" & """=1'-0""") both return 3/16"=1'-0"
tech
Message 3 of 5 (594 Views)
08-13-2012 11:31 AM in reply to: BrentBurgess1980
EDIT
Actually, the " symbol is the culprit. If I create:
strAttValue = ("3/16=1'-0")
it works fine, but I need the " symbol to be part of the string so I am stuck. Any ideas?
When I use a (princ strAttValue) using ssomething like strAttValue = ("3/16" & """=1'-0""")
I get the following error:
bad argument type: FILE "=1'-0"
Moderator
Alexander.Rivilis
Message 4 of 5 (585 Views)
08-13-2012 01:25 PM in reply to: tech
Every Chr(34) have to be replaced with Chr(92) & Chr(34) in order to passed to lisp.
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
_gile
Message 5 of 5 (580 Views)
Re : Pass a string with quote marks to a lisp command in VB.NET
08-13-2012 02:06 PM in reply to: tech
IMO, you'd rather use the Application.Invoke() (A2011 or later), or P/Invoke acedInvoke() (for prior versions) with which you can invoke a LISP function and get its return value.
Your LISP function have to be registered with vl-acad-defun or be prefixed with c:
Here's a little example:
LISP function
(defun lispTest (strArg)
  (princ (strcat "\nstrArg: " strArg "\n"))
  strArg
(vl-acad-defun 'lispTest)
C# code with Application.Invoke():
        [CommandMethod("Foo")]
public void Foo() { ResultBuffer args = new ResultBuffer( new TypedValue((int)LispDataType.Text, "lispTest"), new TypedValue((int)LispDataType.Text, "3/16\"=1'-0\"\"")); ResultBuffer retVal = Application.Invoke(args); Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage( "\nretVal:" + retVal.AsArray()[0].Value); }
C# code with P/Invoke acedInvoke:
        [System.Security.SuppressUnmanagedCodeSecurity]
        [DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl)]
        extern static private int acedInvoke(IntPtr rbIn, out IntPtr rbOut);
        public static ResultBuffer InvokeLisp(ResultBuffer args)
            IntPtr rb = IntPtr.Zero;
            int stat = acedInvoke(args.UnmanagedObject, out rb);
            if (stat == (int)PromptStatus.OK && rb != IntPtr.Zero)
                return (ResultBuffer)DisposableWrapper.Create(typeof(ResultBuffer), rb, true);
            return null;
        [CommandMethod("Bar")]
        public void Bar()
Gilles Chanteau
