.NET
pass a selection set to Autocad
1 REPLY 1
290 Views, 1 Reply
Hi:
How could i pass as selection set defined in managedArx to Autocad as to use
it in the modify properties command
Thanks in advance.
Nermeen Bakr
Project Manager
MCS (Modern Computing Services)
Website: http://www.mcsoil.com
Phone: +2 02 4036520 /+202 4051129
Fax: +2 02 4040503
1 REPLY 1
The Managed SelectionSet classes do not marshal selected
objects as a legacy or "unmanaged" selection set (ads_name),
so there is no way to do this directly, other than by passing
the individual objects in the selection set to acedCommand().
But, in the case of selection sets marshalled by the managed
wrappers, they always originate from a call to acedSSGet()
(there's no way to add objects to them as you can do using
acedSSAdd with unmanaged selection sets). Because of that,
any managed selection set can be retrieved as an unmanaged
selection set, using acedSSGet("_P"), immediately after the
managed selection set is created by a call to an Editor method
such as GetSelection() or what have you.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
"Nermeen Bakr" wrote in message news:4872618@discussion.autodesk.com...
Hi:
Thanks in advance.
Nermeen Bakr
Project Manager
Fax: +2 02 4040503
”Boost
