.NET
16 Kudos
Post 1 of 6
Parametric Dimensions
356 Views, 5 Replies
01-29-2012 09:16 PM
Hey Guys, am in Customization of AutoCAD and the problem am facing is with dimensions.
Am able to get normal dimensions but problem lies in Parametric Dimensions. Any Ideas on how to perform this Linear Constraint Dimension
ADN Support Specialist
80 Kudos
Post 2 of 6
Re: Parametric Dimensions
01-31-2012 02:34 AM in reply to: amitk_189
Hi amitk_189,
Sorry, what is it that you want to do exactly? Do you want to create a dimensional constraint from API? Retrieve information about an existing one? or...?
Creating constraints through the parametric API is a relatively involved task. We created a higher level API in order to help programmers who intent to work with it:
Philippe.
Philippe Leefsma
Developer Consultant
Developer Technical Services
Global Subscription & Support
Autodesk EMEA
www.autodesk.com/joinadn
Philippe Leefsma
Autodesk Developer Network
16 Kudos
Post 3 of 6
02-01-2012 07:25 AM in reply to: amitk_189
In Parameter Tab we have Linear Dimensions, Aligned Dimensions.
Lets draw a Line and the dimension  of this line is 15. Now if i change dimension to 25, the length of line should change to 25. Did you get it now?
And i found this solution you provided in link long time ago but did not succeed in it. I did lot of coding on it but was not able to get things in right order. If atleast one example would have been there it would be helpful.
Valued Mentor
53 Kudos
Post 4 of 6
02-01-2012 08:04 AM in reply to: amitk_189
Philippe & Gopinath,
Just wanted to say thanks for the API in link above and is very useful.
amtik_189,
If I understand you correctly I accomplished what you described using the test commands in MgdConstraintAPITest
MGHLDIMALIGN - to add dimension
MGHLPARAM - to change the "expression" or length of line.
You can also find your answers @ TheSwamp
16 Kudos
Post 5 of 6
02-02-2012 07:25 AM in reply to: amitk_189
Will try
16 Kudos
Post 6 of 6
02-10-2012 02:00 AM in reply to: amitk_189
Nope its not working
