.NET
Palette and Jig
2 REPLIES 2
322 Views, 2 Replies
Palette and Jig
I have a palette with a button to insert blocks via jig. The jig alone
works fine, but calling the jig from the palette does not show the
'ghost', geting the entity from jig works.
By the way: it is AutoCAD 2007.
What's my mistake?
Thanks for any help
Tim
2 REPLIES 2
In AutoCAD 2009 it seems to work, is there any 'fix' for AutoCAD 2007?
Tim
I ran into the same thing. My Jig class drags a ghost circle. When starting
the jig from Palette, the Jig works as expected in Acad2006 (Acad Map 2006
actually), however it did not draw the ghost circle clearly in Acad2007 (I
can see quick flash of the ghost circle), and then it works again in Acad
2008.
So I think it is specific to Acad2007. If so, I'd not hold my breath waiting
for Autodesk to fix it. Moving to later version of Acad would be the
solution.
"Tim Fields" wrote in message
news:6058140@discussion.autodesk.com...
What's my mistake?
Thanks for any help
Tim
”Boost
