.NET
p/invoke acdbEntmod failure
4 REPLIES 4
707 Views, 4 Replies
hello everyone:
i want to p/invoke acdbEntmod method in NETAPI and the codes goes as follows,could u give me some sugguestions?
public static class ObjectIdEx
#if ACAD2014
[DllImport("acdb19.dll", CallingConvention = CallingConvention.Cdecl,
EntryPoint = "?acdbGetAdsName@@YA?AW4ErrorStatus@Acad@@AEAY01_JVAcDbObjectId@@@Z")]
extern static public ErrorStatus acdbGetAdsName(out Int64 entres, ObjectId id);
[DllImport("acCore.dll", CallingConvention = CallingConvention.Cdecl)]
extern static IntPtr acdbEntGet(out Int64 e);
extern static void acdbEntMod(IntPtr ptr);
extern static void acdbEntUpd(Int64 e);
#endif
public static ResultBuffer GetResultBuffer(this ObjectId id)
Int64 e = new Int64();
IntPtr p = new IntPtr();
if (acdbGetAdsName(out e, id) == ErrorStatus.OK)
p = acdbEntGet(out e);
ResultBuffer rb = ResultBuffer.Create(p, true);
return rb;
else return null;
public static void ModifyDxfCodeValue(this ObjectId id, short code, object newTypeValue)
EditorEx.WriteMessage(p.ToString());
ResultBufferEnumerator rbEnum = rb.GetEnumerator();
while (rbEnum.MoveNext())
if (rbEnum.Current.TypeCode == code)
//rbEnum.Current.Value = newTypeValue; <============ read only error here!
EditorEx.WriteMessage(rb.UnmanagedObject.ToString());
ResultBuffer rbMod = new ResultBuffer();
TypedValue[] temp = rb.AsArray();
foreach (TypedValue tp in temp)
TypedValue tpp = new TypedValue();
if (tp.TypeCode != code)
tpp = new TypedValue(tp.TypeCode, tp.Value);
else
tpp = new TypedValue(code, newTypeValue);
rbMod.Add(tpp);
//Interop.DetachUnmanagedObject(rb);
//Interop.AttachUnmanagedObject(rbMod, p, true); <============not available error here!
acdbEntMod(p);
acdbEntUpd(e);
4 REPLIES 4
As I understand you can not change ResultBuffer. Is that true?
TypedValue[] rbArr = rb.AsArray();
for (int i = 0; i < rbArr.Length; i++) {
  if (rbArr[i].TypeCode == code) {
    rbArr[i] = new TypedValue(code, newTypeValue);
rb.Dispose();
rb = new ResultBuffer(rbArr);
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
As Alex notes, you can't modify a ResultBuffer from managed code.
You should just work with an array of TypedValue[], and then
create a new ResultBuffer and pass the value of its UnmanagedObject
property to native code that requires a resbuf* pointer.
in reply to: 275171906
is there anyway to use pointer(resultbuffer* ,eg) in managed code?
Are you about this:
IntPtr p = IntPtr.Zero;
// p - pointer to first resbuf structure in resbuf list
// Creating managed ResultBuffer from unmanaged resbuf pointer ResultBuffer rb = ResultBuffer.Create(p, true);
// Now we can manipulate with managed rb
// Getting unmanaged pointer to resbuf from managed ResultBuffer
p = rb.UnmanagedObject;
Expert Elite Member
”Boost
