.NET
Distinguished Contributor
quigs
Message 1 of 12 (377 Views)
Overuled blocks appear darker.
377 Views, 11 Replies
01-11-2013 02:35 AM
Hi there,
In some of our polyline overrules we have blocks, the problem is that those blocks are coming in at a darker colour.  It's as if  they are permanently selected.  Has anyone come across this before?
Thank you,
Maritn.
My name is Martin.. :smileyvery-happy:
Valued Mentor
DiningPhilosopher
Message 2 of 12 (361 Views)
Re: Overuled blocks appear darker.
01-11-2013 06:39 AM in reply to: quigs
You might want to rephrase your question because it's vague.
What are you doing, with blocks and overrules ?
quigs
Message 3 of 12 (359 Views)
01-11-2013 06:53 AM in reply to: DiningPhilosopher
Ok, I will try and be more descreiptive.
We have a function that applies an Overrule to 2dPolyLine.  The overrule consists of Blocks in the shape of a triangle that are copied along the polyline at a selected distance.  The colour of the triangles is the issue.  Basically we set the triangle block to colour index 2 (yellow), but it displays at a darker yellow.  And that applies for nay colour.  If you move the polyline the blocks colour appears correct, then when you set it back down it goes back to being dark.
Martin.
quigs
Message 4 of 12 (353 Views)
01-11-2013 07:49 AM in reply to: quigs
I'm just wondering if this is a bug in the worlddraw?  We can't seem to find a solution apart from darken all the other stuff to match the miss coloured block.  Very frustrating.
Valued Mentor
DiningPhilosopher
Message 5 of 12 (338 Views)
01-11-2013 03:38 PM in reply to: quigs
Sorry, still really not enough to diagnose the problem, which is probably in your WorldDraw() implementation.
quigs
Message 6 of 12 (300 Views)
01-15-2013 06:47 AM in reply to: DiningPhilosopher
It is the worlddraw we have overridden, but why would  a block reference in the worlddraw of an overrule be darker?
I have a feeling it's something to do with the fact that it thinks it's being moved even when it's not.
Ta,
Martin.
quigs
Message 7 of 12 (269 Views)
01-18-2013 04:27 AM in reply to: quigs
We have just ran more tests.  The bug shws up in 2011 & 2012.  BUt the same code ran in 2010 works fine, with no discoloration.  I have attached a sample project.
Regards.
Maritn.
quigs
Message 8 of 12 (266 Views)
01-18-2013 04:45 AM in reply to: quigs
Oops,
here it is.
PS: Make sure to open the drawing first so the block is loaded into the drawing.
quigs
Message 9 of 12 (222 Views)
01-23-2013 05:29 AM in reply to: quigs
Hi there Balaji,
were you able to re-create the problem were having?
Maritn.
ADN Support Specialist
Balaji_Ram
Message 10 of 12 (212 Views)
01-23-2013 09:12 PM in reply to: quigs
Hi Martin,
Sorry, your post seemed to indicate that you had resolved it :smileyhappy:
If you still have this issue, let me know and I will try it out right away.
Balaji
Developer Technical Services
Autodesk Developer Network
