.NET
annse
Message 1 of 18 (535 Views)
Override default commands
535 Views, 17 Replies
04-04-2012 03:01 AM
Hi!
I'm trying to do something like this:
[Autodesk.AutoCAD.Runtime.CommandMethod("REFEDIT", Autodesk.AutoCAD.Runtime.CommandFlags.UsePickSet)]
public void RefEdit()
Document doc = AcadApp.DocumentManager.MdiActiveDocument;
if (doc is a document I care about))
do my stuff...
else
run the default command...
I haven't undefined the default command, my definition of REFEDIT executes anyway.
I wanna be able to run the default command from my definition.
doc.SendStringToExecute(".REFEDIT ", true, false, false); will loop forever.
This code was tested with AutoCAD 2011-2013:
using System;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
[assembly: ExtensionApplication(typeof(Rivilis.RefEditSubst))]
[assembly: CommandClass(typeof(Rivilis.RefEditSubst))]
namespace Rivilis
    public class RefEditSubst : IExtensionApplication
        void IExtensionApplication.Initialize()
            // Preloading AutoCAD RefEdit command arx-file
            SystemObjects.DynamicLinker.LoadModule("AcRefEd.arx", false, false);
        void IExtensionApplication.Terminate()
            // Do plug-in application clean up here
        //     Command group MUST be "ACAD_MAIN"
        [CommandMethod("ACAD_MAIN", "RefEdit", CommandFlags.UsePickSet)]
        public void RefEdit() // This method can have any name
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            ed.WriteMessage("MyRefEdit..");
            if (doc.Name.Contains("Test"))
                ed.WriteMessage("selected ref..");
            else
                doc.SendStringToExecute("_ACAD_REFEDIT.REFEDIT ", true, false, false);
ADN Support Specialist
Balaji_Ram
Message 2 of 18 (527 Views)
Re: Override default commands
04-04-2012 05:40 AM in reply to: annse
I tried this which is very similar to what you are trying and it worked ok.
With this code, the line command is redefined only for drawings that have "Test" in their name.
Can you try this and see if it works for you ?
Maybe it will then help you identify the reason for your code to loop indefinitely.
// Add reference to Autodesk.AutoCAD.Interop
// Add reference to Autodesk.AutoCAD.Interop.Common
using Autodesk.AutoCAD.Interop;
using Autodesk.AutoCAD.Interop.Common;
[CommandMethod("LINE")]
static public void LineMethod()
        ed.WriteMessage("My implementation of line");
    else
        AcadApplication app = (AcadApplication)Application.AcadApplication;
        app.ActiveDocument.SendCommand("_.LINE ");
    app.ActiveDocument.SendCommand("_.UNDEFINE _LINE ");
Balaji
Developer Technical Services
Autodesk Developer Network
annse
Message 3 of 18 (517 Views)
04-04-2012 06:58 AM in reply to: Balaji_Ram
Thank you for your quick response!
I've added required references and I now use SendCommand instead of SendStringToExecute.
This will still loop indefinitely. (If doc.Name doesn't contain "Test")
public void Initialize()
app.ActiveDocument.SendCommand("_.UNDEFINE _REFEDIT ");
static public void RefEdit()
ed.WriteMessage("New refedit...");
else
app.ActiveDocument.SendCommand("_.REFEDIT ");
Thanks again!
Balaji_Ram
Message 4 of 18 (511 Views)
04-04-2012 08:36 AM in reply to: annse
With the Line command the code does work.
But there seems to be some problem with using it for "Refedit".
Can you check if the command is actually undefined after sending the "undefine" command ?
Balaji
Moderator
Alexander.Rivilis
Message 5 of 18 (499 Views)
04-04-2012 11:42 AM in reply to: Balaji_Ram
What about:
app.ActiveDocument.SendCommand("_ACAD_REFEDIT.REFEDIT ");
Command _REFEDIT defined in file AcRefEd.arx
If your's dll-file loaded after AcRefEd.arx - than no need to _UNDEFINE _REFEDIT, because your command REFEDIT override standard command REFEDIT. And standard command REFEDIT can be invoked using _ACAD_REFEDIT.REFEDIT
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
annse
Message 6 of 18 (481 Views)
04-04-2012 11:32 PM in reply to: Balaji_Ram
Hi!
When I do the same thing with LINE instead of REFEDIT, my new definition of LINE won't run.
I get this error with both LINE and REFEDIT.
_.UNDEFINE
; error: no function definition: ACET-STR-REPLACE
_LINE
Thanks!
annse
Message 7 of 18 (478 Views)
04-04-2012 11:46 PM in reply to: Alexander.Rivilis
Thanks, Alexander! That works!
My dll is loaded in a .bundle installation.
So, because I can't override _LINE the same way, _LINE is loaded after my dll and _REFEDIT before?
Thanks again!
annse
Message 8 of 18 (472 Views)
04-05-2012 12:29 AM in reply to: Alexander.Rivilis
If the timing issue is irrelevant due to that the _REFEDIT command is already defined when my dll is loading,
I can use SendStringToExecute instead of SendCommand?
This way I won't have to echo the command.
Thanks again!
Moderator
Alexander.Rivilis
Message 9 of 18 (468 Views)
04-05-2012 12:39 AM in reply to: annse
I think you can do it. Try!  :-)
annse
Message 10 of 18 (460 Views)
04-05-2012 03:32 AM in reply to: Alexander.Rivilis
Hello again...
Sending "_ACAD_REFEDIT.REFEDIT " seems to redefine the command.
If the string is executed, the next time you run REFEDIT, it'll run the default definition.
[Autodesk.AutoCAD.Runtime.CommandMethod("REFEDIT", Autodesk.AutoCAD.Runtime.CommandFlags.Session & Autodesk.AutoCAD.Runtime.CommandFlags.UsePickSet)]
static public void RefEditDef()
else
Any ideas?
Thanks!
