.NET
Outputting a dxf file from an active drawing.
1 REPLY 1
baw6718
562 Views, 1 Reply
I have several closed ployline shapes  in a particular layer, I need to know a way to:
a) pick all the entites on that layer
b) export to a dxf file each individual entity on the layer (yes, each entity saved to a separate dxf)
Any help would be great. I am almost positive I can answer 'a' on my own using an object collection and a conditional statement? I am really more interested in how to export an entity from current open drawing to a dxf file in .net
1 REPLY 1
norman.yuan
in reply to: baw6718
Try this code:
using System.IO;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
[assembly: CommandClass(typeof(DxfOut.MyCommands))]
namespace DxfOut
    public class MyCommands
        [CommandMethod("MyDxfOut")]
        public static void RunMyCommand()
            Document dwg = Application.DocumentManager.MdiActiveDocument;
            Editor ed = dwg.Editor;
            PromptSelectionResult res = ed.GetSelection();
            if (res.Status != PromptStatus.OK)
                ed.WriteMessage("\n*Cancel*");
                return;
            string folderPath = @"C:\Temp\ExportedFiles";
            try
                ExportEntityToDxf(dwg.Database, res.Value.GetObjectIds(), folderPath);
                ed.WriteMessage("\nSelected entities exported");
            catch (System.Exception ex)
                ed.WriteMessage("\nError: {0}", ex.ToString());
            Autodesk.AutoCAD.Internal.Utils.PostCommandPrompt();
        private static void ExportEntityToDxf(
            Database sourceDB, ObjectId[] entIds, string folderName)
            int i=0;
            foreach (ObjectId id in entIds)
                i++;
                string fileName =
                    folderName + "\\Test" + i + "_" + id.ObjectClass.DxfName + ".dxf";
                if (File.Exists(fileName)) File.Delete(fileName);
                using (Database db = new Database(true, true))
                    ObjectIdCollection ids = new ObjectIdCollection(new ObjectId[]{id});
                    sourceDB.Wblock(db, ids, Point3d.Origin, DuplicateRecordCloning.Ignore);
                    db.DxfOut(fileName, 16, DwgVersion.Current);
 I use AutoCAD2012. I started a drawing, drew a few entities (lines, circles...), placed them in different layers, colors. Then run the command "MyDxfOut". I ended up with a bunch of *.dxf files in C:\temp folder, which I opened in AutoCAD, and saw each Dxf file has a single entity with its layer/color being the same as the source entity.
HTH.
”Boost
