.NET
Active Member
1 Kudo
Post 1 of 3
Out of process VB.Net
373 Views, 2 Replies
11-10-2010 04:40 PM
Can anyone point me in the right direction for this one?
Want to write an out of process EXE that I can call with an argument, a file pathname and then search the block table for a particular block and if found extract the attribute values.  Have the last part working fine but am having some trouble getting the AutoCAD connection section working correctly.  Assume that I'll need to use COM Interop but I have yet to come up with a solid example.
Really appreciate some code examples.
Thanks in advance.
Valued Contributor
0 Kudos
Post 2 of 3
Re: Out of process VB.Net
11-11-2010 03:26 AM in reply to: PacificorpJB
Try exploring this code.
[code]
using System;
using System.Collections.Generic;
using System.Text;
using System.Reflection;
namespace acad_net
    class Program
        static void Main(string[] args)
            //Instance of AutoCAD
            Type AppType = Type.GetTypeFromProgID("Autocad.Application");
            Object App = Activator.CreateInstance(AppType);
            // Get AcadDocuments
            Object doc =
            AppType.InvokeMember("documents",
                BindingFlags.DeclaredOnly |
                BindingFlags.Public | BindingFlags.NonPublic |
                BindingFlags.Instance | BindingFlags.GetProperty, null, App, null);
            // Open a document and add it to the current database
            doc =
            doc.GetType().InvokeMember("open",
               BindingFlags.Instance | BindingFlags.InvokeMethod, null, doc, new Object[] { "C:\\drawing2.dwg", false });
            // Make the document visible
            AppType.InvokeMember("visible",
                BindingFlags.Instance | BindingFlags.SetProperty, null, App, new Object[] { 1 });
             // Execute some command - zoom for this example
            doc.GetType().InvokeMember("sendcommand",
              BindingFlags.Instance | BindingFlags.InvokeMethod, null, doc, new Object[] { "zoom e " });
            Object ut = // utility object
               doc.GetType().InvokeMember("utility",
               BindingFlags.Instance | BindingFlags.GetProperty, null, doc, null);
            // Some prompt
            ut.GetType().InvokeMember("prompt",
            BindingFlags.Instance | BindingFlags.InvokeMethod, null, ut, new Object[] { "Hello Hello Hello Hello : " });
            // execute netload - if you fant to load something - load it yourself :smileyhappy:
            doc = doc.GetType().InvokeMember("sendcommand",
              BindingFlags.Instance | BindingFlags.InvokeMethod, null, doc, new Object[] { "netload" });
[/code]
Active Member
1 Kudo
Post 3 of 3
11-11-2010 08:25 AM in reply to: ognyandim
Thank you I'll try and take a look today.
