.NET
Active Contributor
cincir
Message 1 of 3 (247 Views)
OSnapOverrule crashes AutoCAD
247 Views, 2 Replies
11-15-2012 03:01 PM
hello everyone
i have a problem about OsnapOverrule. when i register a derived class of OsnapOverrule doing nothing but only calling the base classes GetObjectSnapPoints function , Autocad crashes after object snap tracking from the end point along the direction of polyline occurs. if i unchecked "extension" from object snap it just works fine. it only crashes while object snap tracking. Code is so plain as i said but i am posting it just in case
public class OsnapOverruleDemo : OsnapOverrule
        private static OsnapOverruleDemo _singleton;
        public static OsnapOverruleDemo Instance
            get
                if (_singleton == null)
                    _singleton = new OsnapOverruleDemo();
                return _singleton;
        protected OsnapOverruleDemo()
            : base()
        public void Register()
            if (!Overrule.HasOverrule(Instance,RXClass.GetClass(typeof(Autodesk.AutoCAD.DatabaseServices.Polyline))))
                Overrule.AddOverrule(RXClass.GetClass(typeof(Autodesk.AutoCAD.DatabaseServices.Polyline)), Instance, true);
        public void UnRegister()
            if (Overrule.HasOverrule(Instance, RXClass.GetClass(typeof(Autodesk.AutoCAD.DatabaseServices.Polyline))))
                Overrule.RemoveOverrule(RXClass.GetClass(typeof(Autodesk.AutoCAD.DatabaseServices.Polyline)), Instance);
        public override void GetObjectSnapPoints(Entity entity, ObjectSnapModes snapMode, IntPtr gsSelectionMark, Point3d pickPoint, Point3d lastPoint, Matrix3d viewTransform, Point3dCollection snapPoints, IntegerCollection geometryIds, Matrix3d insertionMat)
            base.GetObjectSnapPoints(entity, snapMode, gsSelectionMark, pickPoint, lastPoint, viewTransform, snapPoints, geometryIds, insertionMat);
    public class Demo
        [CommandMethod("OverruleOn")]
        public static void OverruleOn()
            OsnapOverruleDemo.Instance.Register();
should i also implement other overrule functions like GeometryOverrules IntersectWith function or something like this?
thanks.
ADN Support Specialist
Balaji_Ram
Message 2 of 3 (210 Views)
Re: OSnapOverrule crashes AutoCAD
11-21-2012 08:08 AM in reply to: cincir
I could reproduce the crash in AutoCAD 2011 / 2012 and 2013.
The issue seems to be specific to polyline and the extension osnap.
I have logged this behavior in our internal database for our engineering team to analyze.
Sorry, there is no workaround that I could find.
Balaji
Developer Technical Services
Autodesk Developer Network
Active Contributor
cincir
Message 3 of 3 (192 Views)
11-22-2012 08:11 AM in reply to: cincir
Thank you.
