I have no problem displaying a modal form from a control on a tab on the options dialog (I only tried that in AutoCAD 2009 however, can't vouch for what happens in earlier releases).
So, I suppose that the problem may have something to do with your form and what it is doing when you show it.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
wrote in message news:5986305@discussion.autodesk.com...
I've created an additional tab in the standard options dialog. This works fine, however I am having trouble opening a dialog box from the tab. I'm usign the following code:
Dim frm1 As diag_Printers = New diag_Printers
Application.ShowModalDialog(frm1)
When I use this code with CommandMethod it works fine. When I try and run it from clicking a button on my new options tab AutoCAD crashes. The form does appear, however it is blank and doesn't respond.
Any solutions to this or am I not able to open a dialog from the options.
Message was edited by: DavidScott
