.NET
Open Sheet Set in Sheet Set Manager
3 REPLIES 3
ChrisPicklesimer
1197 Views, 3 Replies
ACA 2012
I understand how to create/open a sheet set so that I am able to do things such as add pages and subsets, modify properties, rename and renumber pages, etc.  However, when I open the sheet set progrmatically, it does not show up as open in the sheet set manager.  Is it possible to have an open sheet set display as one of the open sheet sets in the SSM?
Dim sheetSetManager AsIAcSmSheetSetMgr sheetSetManager =NewAcSmSheetSetMgr
Dim sheetSetDatabase AsAcSmDatabase sheetSetDatabase = sheetSetManager.CreateDatabase(myNewFile, myTemplate, True)
sheetSetManager.OpenDatabase(myNewFile, False)
Thanks.
Chris
3 REPLIES 3
Hi, Chris,
the only way I found is open Sheet Set in command line.
Here is example on C#:
Application.DocumentManager.MdiActiveDocument.SendStringToExecute(".-opensheetset \"" + _fullFileName + "\"\n", true, false, false);
Thanks!  That does exactly what I need.
Hi Chris,
You can use below code for to open SheetSet manager from C#
string FullPath  = "C:\\Siva\\Sivakumar\\Software\\AutoCad\\POC\\SheetSet\\Demo007.dst";
cadApp.ActiveDocument.SendCommand(".-opensheetset \"" + FullPath + "\"\r");
Sivakumar N
”Boost
