.NET
.NET
Valued Contributor
Chris.Picklesimer
Message 1 of 3 (342 Views)
Open Sheet Set in Sheet Set Manager
342 Views, 2 Replies
10-07-2013 06:15 AM
ACA 2012
I understand how to create/open a sheet set so that I am able to do things such as add pages and subsets, modify properties, rename and renumber pages, etc.  However, when I open the sheet set progrmatically, it does not show up as open in the sheet set manager.  Is it possible to have an open sheet set display as one of the open sheet sets in the SSM?
Dim sheetSetManager AsIAcSmSheetSetMgr sheetSetManager =NewAcSmSheetSetMgr
Dim sheetSetDatabase AsAcSmDatabase sheetSetDatabase = sheetSetManager.CreateDatabase(myNewFile, myTemplate, True)
sheetSetManager.OpenDatabase(myNewFile, False)
Thanks.
Chris
Thanks!  That does exactly what I need.
Member
vladimior
Message 2 of 3 (315 Views)
Re: Open Sheet Set in Sheet Set Manager
10-08-2013 11:21 AM in reply to: Chris.Picklesimer
Hi, Chris,
the only way I found is open Sheet Set in command line.
Here is example on C#:
Application.DocumentManager.MdiActiveDocument.SendStringToExecute(".-opensheetset \"" + _fullFileName + "\"\n", true, false, false);
Valued Contributor
Chris.Picklesimer
Message 3 of 3 (308 Views)
10-08-2013 01:00 PM in reply to: Chris.Picklesimer
