.NET
.NET
New Member
daniel.messenger
Message 1 of 2 (1,418 Views)
'Open' is not a member of ApplicationServices.DocumentCollection
1418 Views, 1 Replies
04-25-2012 08:40 AM
I have a VB.NET 4.0 app which was working fine with references to ObjectARX 2011.
I have removed these references and added references to ObjectARX2013, and now I get the following error at compile time:
'Open' is not a member of 'Autodesk.AutoCAD.ApplicationServices.DocumentCollection'
Code:
Dim docs As DocumentCollection
docs = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
docs.Open(sDrawingPath, False)
Everything else works fine - if I common out the last line then it compiles fine.
Does anybody have any ideas?
DocumentCollectionExtension.Open
P.S.: Also read ObjectARX for AutoCAD 2013 Docs: Managed Class Reference -> Migration Guide->.NET Migration Guide
Moderator
Alexander.Rivilis
Message 2 of 2 (1,410 Views)
Re: 'Open' is not a member of ApplicationServices.DocumentCollection
04-25-2012 10:14 AM in reply to: daniel.messenger
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
