.NET
Open AutoCAD Application 2007?
2 REPLIES 2
221 Views, 2 Replies
Okay, i give.
I'm trying to update some of out VB.net routines to use AutoCAD 2007. I've added
the COM reference to 2007 type library, but I can't even get AutoCAD 2007 to
open properly. When I run the code below, I just get a couple of pallets, but no
document window...
Any help would be
appreciated!
Thanks.
Private
color=#0000ff size=2>Sub
Button1_Click(
color=#0000ff size=2>ByVal
sender
size=2>As
System.Object,
size=2>ByVal
e
size=2>As
System.EventArgs)
size=2>Handles
Button1.Click
Me.Close()
acad =
New
AutoCAD.AcadApplication
dwg =
color=#0000ff>New
AutoCAD.AcadDocument
dwg = acad.Documents.Add("acad.dwt")
End
2 REPLIES 2
acad.visible = true
That did it. Thanks!
wrote in message news:5258746@discussion.autodesk.com...
acad.visible = true
”Boost
