.NET
Open a drawing file programmatically
7 REPLIES 7
Message 1 of 8
dynamicscope
2360 Views, 7 Replies
Dear. Developpers.
I am trying to open a drawing file programmatically(automatically).
So for example.
If I have a file name "test.dwg" and run some custom command like 'openfile", AutoCAD opens "test.dwg" without any prompt.
The following code DOESN'T do the job I want.
Application.DocumentManager.MdiActiveDocument.SendStringToExecute("OPEN", true, false, true)
The problem is I have to hit enter after the above code is run.
Would there be any way to do this?
7 REPLIES 7
Message 2 of 8
Use following code where DictionaryEntry.Key is the name of the drawing to be opened (full name incl. path)
ForEach DictionaryEntry In DictionaryDrawingNames
     If DictionaryEntry.Value = TrueThen
          CurrentDrawings.Open(DictionaryEntry.Key,False)
  EndIf
Next
Cheers
Message 3 of 8
Sorry: forgot to put in the definition for CurrentDrawings which is
Dim CurrentDrawings AsDocumentCollection = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
Message 4 of 8
Great~! Thx.
Could I ask one more question?
Do you also know how to open on a currently opened document(window)?
For example, when you first run AutoCAD, "drawing1.dwg" document is opened by default.
So I want to place(or replace) my 'test.dwg" on that document.
The code above opens the file in a new window.
Thank you a lot for your help. 😃
Message 5 of 8
You have not sent the "new line" to the commandline, you just sent "OPEN", if you want to work with SendStringToExecute (what I would not prefere if there is another solution available), then do it including sending the carridge-return:
Application.DocumentManager.MdiActiveDocument.SendStringToExecute("OPEN" & vbCr, true, false, true)
Activate the "test.dwg" and close the other drawing? But I'm not sure if that is what you are asking for?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 6 of 8
dynamicscope
in reply to: dynamicscope
Thank you.
How can I active a document?
Message 7 of 8
depending on the session-flag in the command-definition when opening a drawing it will be made the active one.
If you have a list of drawings already opened and want to make a specific one the active one then set the Application.DocumentManager.MdiActiveDocument = newDoc
or use the COM-version like
ctype(newDoc,Interop.AcadDocument).Activate
- alfred -
Alfred NESWADBA
Message 8 of 8
This doesn't seem to work for 2013. Says that the CurrentDrawings.open is not a member of the DocumentCollection. Did they move it in the API??
Steve Hill
Civil Designer / .NET Developer
AutoCAD Civil 3D Certified Professional
http://redtransitconsultants.com/
Autodesk Exchange Store
Twitter | LinkedIn
Please select the Accept this solution button if my post solves your issue or answers your question.
”Boost
