.NET
Valued Contributor
dynamicscope
Message 1 of 8 (1,017 Views)
Open a drawing file programmatically
1017 Views, 7 Replies
04-09-2012 10:57 PM
Dear. Developpers.
I am trying to open a drawing file programmatically(automatically).
So for example.
If I have a file name "test.dwg" and run some custom command like 'openfile", AutoCAD opens "test.dwg" without any prompt.
The following code DOESN'T do the job I want.
Application.DocumentManager.MdiActiveDocument.SendStringToExecute("OPEN", true, false, true)
The problem is I have to hit enter after the above code is run.
Would there be any way to do this?
Use following code where DictionaryEntry.Key is the name of the drawing to be opened (full name incl. path)
ForEach DictionaryEntry In DictionaryDrawingNames
     If DictionaryEntry.Value = TrueThen
          CurrentDrawings.Open(DictionaryEntry.Key,False)
  EndIf
Next
Cheers
depending on the session-flag in the command-definition when opening a drawing it will be made the active one.
If you have a list of drawings already opened and want to make a specific one the active one then set the Application.DocumentManager.MdiActiveDocument = newDoc
or use the COM-version like
ctype(newDoc,Interop.AcadDocument).Activate
- alfred -
Active Member
TobyRosenberg8728
Message 2 of 8 (1,016 Views)
Re: Open a drawing file programmatically
04-09-2012 11:08 PM in reply to: dynamicscope
  EndIf
Next
Cheers
Active Member
TobyRosenberg8728
Message 3 of 8 (1,015 Views)
04-09-2012 11:09 PM in reply to: TobyRosenberg8728
Sorry: forgot to put in the definition for CurrentDrawings which is
Dim CurrentDrawings AsDocumentCollection = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
Valued Contributor
dynamicscope
Message 4 of 8 (1,009 Views)
04-09-2012 11:33 PM in reply to: TobyRosenberg8728
Great~! Thx.
Could I ask one more question?
Do you also know how to open on a currently opened document(window)?
For example, when you first run AutoCAD, "drawing1.dwg" document is opened by default.
So I want to place(or replace) my 'test.dwg" on that document.
The code above opens the file in a new window.
Thank you a lot for your help. =)
Alfred.NESWADBA
Message 5 of 8 (993 Views)
04-10-2012 12:56 AM in reply to: dynamicscope
You have not sent the "new line" to the commandline, you just sent "OPEN", if you want to work with SendStringToExecute (what I would not prefere if there is another solution available), then do it including sending the carridge-return:
Application.DocumentManager.MdiActiveDocument.SendStringToExecute("OPEN" & vbCr, true, false, true)
Activate the "test.dwg" and close the other drawing? But I'm not sure if that is what you are asking for?
- alfred -
Alfred NESWADBA
Valued Contributor
dynamicscope
Message 6 of 8 (982 Views)
04-10-2012 02:05 AM in reply to: dynamicscope
Thank you.
How can I active a document?
Alfred.NESWADBA
Message 7 of 8 (979 Views)
04-10-2012 02:19 AM in reply to: dynamicscope
- alfred -
Alfred NESWADBA
stevenh0616
Message 8 of 8 (739 Views)
12-12-2012 01:32 PM in reply to: TobyRosenberg8728
This doesn't seem to work for 2013. Says that the CurrentDrawings.open is not a member of the DocumentCollection. Did they move it in the API??
Steve
Windows 7 Enterprise 64-bit SP1
Intel Core i7 CPU X920 @ 1.73 GHz
16.00 GB RAM
Civil 3D 2013 - 2015
Check out my AutoCAD, Civil 3D, and Map Apps on the Autodesk Exchange Store at: Autodesk Exchange Store
