.NET
OnLoad Event
2 REPLIES 2
wesbird
314 Views, 2 Replies
OnLoad Event
HI,
I am looking for a DLL OnLoad event. I plan to do some environment setup, like menu, environment variable ...
but I can not find this event.
Also I am looking a way to set up global varible in .Net. I try use static which not work for my case. for each command I am going to run in AutoCAD, 1st thing I would do is, query database, get all setting, put in a class which I can access anywhere in my code. I tried Dynamic Properties, but I don't think it will work.
Thank you in advance.
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
2 REPLIES 2
in reply to: wesbird
You need to have a class in your assembly implement the
IExtensionApplication interface.
Bobby C. Jones
http://www.acadx.com
wrote in message news:5004118@discussion.autodesk.com...
HI,
Wes
wesbird
thank you, I will try it.
”Boost
