.NET
okok Now what?
11 REPLIES 11
Message 1 of 12
850 Views, 11 Replies
okok Now what?
I want to call COM objects from VB.NET
i set a reference under the COM tab for AutoCAD 2006 Type Library and
the AutoCAD/ObjectDBX Common 16.0 Type Library.
i used "Imports Autodesk.AutoCAD.Interop "
now how to get a pointer to, for example, the active document?
thanks for any help
jm
11 REPLIES 11
Message 2 of 12
Imports Autodesk.AutoCAD.InterOp
Imports Autodesk.AutoCAD.InterOp.Common
-- Mike
___________________________
Mike Tuersley
the trick is to realize that there is no spoon...
Message 3 of 12
Here is a c# class to create a circle,
and the call to the dll from VBA.
gl
Paul
Sub test()
Dim circle1 As New AddCircle.Circle
Dim xCoord As Double: xCoord = 10
Dim yCoord As Double: yCoord = 10
Dim zCoord As Double: zCoord = 0
Dim rad As Double: rad = 25
circle1.xCoord = xCoord
circle1.yCoord = yCoord
circle1.zCoord = zCoord
circle1.Radius = rad
circle1.Draw
End Sub
using System;
using System.Runtime.InteropServices;
using Autodesk.AutoCAD.Interop;
using Autodesk.AutoCAD.Runtime;
namespace AddCircle
namespace MyCircleClass
/// Summary description for Circle.
public interface IMyInterface1
double xCoord { set; get; }
double yCoord { set; get; }
double zCoord { set; get; }
double radius { set; get; }
void Draw();
// Class that implements the Interface
[ ClassInterface( ClassInterfaceType.None ) ]
public class Circle : IMyInterface1
private double _xCoord;
private double _yCoord;
private double _zCoord;
private double _radius;
public double zCoord
get
return _zCoord;
set
_zCoord = value;
} // interface properties implemented by zCoord
double IMyInterface1.zCoord
get { return zCoord; }
set { zCoord = value; }
public double xCoord
get
return _xCoord;
set
_xCoord = value;
} // interface properties implemented by xCoord
double IMyInterface1.xCoord
get { return xCoord; }
set { xCoord = value; }
public double yCoord
get
return _yCoord;
set
_yCoord = value;
} // interface properties implemented by yCoord
double IMyInterface1.yCoord
get { return yCoord; }
set { yCoord = value; }
public double radius
get
return _radius;
set
_radius = value;
double IMyInterface1.radius
get { return radius; }
set { radius = value; }
public void Draw()
double[] centerPoint = new double[3];
AcadApplication myApp = Helper.GetAcad();
myApp.Visible = true;
AcadDocument myDoc = myApp.ActiveDocument;
centerPoint[0] = _xCoord;
centerPoint[1] = _yCoord;
centerPoint[2] = _zCoord;
myDoc.ModelSpace.AddCircle(centerPoint,_radius);
"john m" wrote in message
news:4852713@discussion.autodesk.com...
thanks for any help
jm
Message 4 of 12
Sample Class to draw a circle,
and call from VBa. Sorry if this
posted twice. Email issues.
Sub test()
circle1.Draw
End Sub
using System;
namespace AddCircle
void Draw();
get
return _zCoord;
set
_zCoord = value;
get
return _xCoord;
set
_xCoord = value;
get
return _yCoord;
set
_yCoord = value;
get
return _radius;
set
_radius = value;
public void Draw()
thanks for any help
jm
Message 5 of 12
btw. Not that I need to ask:-) but
could someone please tell me if
there is anything I am doing wrong.
I know the namespaces would make
more sense if I had flipped them making
"MyCircleClass" the main namespace.
and having "AddCircle" as a nested space.?
tks
Paul
"Paul Richardson" wrote in message
news:4852753@discussion.autodesk.com...
gl
Paul
Sub test()
circle1.Draw
End Sub
using System;
namespace AddCircle
void Draw();
get
return _zCoord;
set
_zCoord = value;
get
return _xCoord;
set
_xCoord = value;
get
return _yCoord;
set
_yCoord = value;
get
return _radius;
set
_radius = value;
public void Draw()
thanks for any help
jm
Message 6 of 12
thanks for the hint mike
i am an idiot and still lost
here is my code
Dim thisapp As Autodesk.AutoCAD.Interop.AcadApplicationClass
Dim thisDrawing As Autodesk.AutoCAD.Interop.AcadDocumentClass
thisDrawing = thisapp.ActiveDocument
it compiles fine and then when i do netload it says the third line is no
good
thank you for looking at it
jm
"Mike Tuersley" wrote in message
news:4852731@discussion.autodesk.com...
-- Mike
Mike Tuersley
Message 7 of 12
>good
What are you compiling it to? Are you creating a NET object
or a COM object? Why the NETLOAD?
news:4852749@discussion.autodesk.com...
here is my code
good
jm
-- Mike
Mike Tuersley
Message 8 of 12
i found an example of using the COM API
so i am making better progress now
the idea was that i wanted to use dotNet xml features and also resizable
forms
but still use the autocad COM
thanks all
news:4852795@discussion.autodesk.com...
>good
here is my code
good
jm
-- Mike
Mike Tuersley
Message 9 of 12
cool. Sorry for the C#. Though u were using
sharp not vb.
news:4852774@discussion.autodesk.com...
forms
thanks all
>good
here is my code
good
jm
-- Mike
Mike Tuersley
Message 10 of 12
I'm also working on a AutoCAD automation project.
And the code that I found here is very usefully, only : where does the function Helper.GetAcad(); come from?
BR,
Gunther S
Message 11 of 12
Dang....All that code just to create a circle??
Sorry....couldn't resist.
Message 12 of 12
Sorry I didn't see your post, I use a news-reader
not the browser usually.
'Helper' is just the name oft the class that holds
the method to connect to autocad 'GetAcad'.
Could be anything, it was the name used in the
Lab I was following by Roy Pereira.
”Boost
