You're probably not going to have much luck
requesting custom sample code here. That's
because unlike LISP or VBA, even simple things
are fairly complicated and involved, to the point
where providing you with custom samples is
not something that most are willing to do.
If you're extremely lucky, perhaps someone may
have done what you need already as part of real
work, and can share some of the code they wrote
for it, but just don't hold your breath.
The Curve class has a method called GetOffsetCurves()
which is where you need to start. However, I would
suggest that you spend some time becoming more
familiar with the API before trying to tackle something
like this, because unlike the few lines of LISP that's
needed to do this, the same in .NET it is not trivial.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5500554@discussion.autodesk.com...
Hi, all.
Could anyone share 'Offset Polyline' example code?
I found the example code written in LISP, but what I need is .net example.
I would be much and much .... appreciated if you do that.
