.NET
Active Contributor
xdbk07
Message 1 of 5 (744 Views)
Offset polyline by pick point on side like autocad
744 Views, 4 Replies
02-03-2013 05:32 PM
Hi pro,
Please let me know how to offset a opened polyline by pick point on side of opened polyline.
With minimum error checking. Only as idea.
using System;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
[assembly: CommandClass(typeof(Rivilis.CurveUtils))]
namespace Rivilis
public class CurveUtils
[CommandMethod("OffsetCurve", CommandFlags.Modal)]
public static void OffsetCurve()
Document doc = Application.DocumentManager.MdiActiveDocument;
Editor ed = doc.Editor;
PromptDoubleResult resValueOff = ed.GetDistance("\nOffset value: ");
if (resValueOff.Status != PromptStatus.OK) return;
PromptPointResult resPointOff = ed.GetPoint("\nOffset side: ");
if (resPointOff.Status != PromptStatus.OK) return;
PromptEntityOptions prCurv = new PromptEntityOptions("\nSelect curve: ");
prCurv.SetRejectMessage("not a Curve");
prCurv.AddAllowedClass(typeof(Curve),false);
PromptEntityResult resCurv = ed.GetEntity(prCurv);
if (resCurv.Status != PromptStatus.OK) return;
using (Transaction tr = doc.TransactionManager.StartTransaction()) {
Curve curve = tr.GetObject(resCurv.ObjectId, OpenMode.ForRead) as Curve;
if (curve != null) {
BlockTableRecord btr = tr.GetObject(curve.BlockId, OpenMode.ForWrite) as BlockTableRecord;
if (btr != null) {
Point3d pDir = (Point3d)(Application.GetSystemVariable("VIEWDIR"));
if (pDir != null) {
Point3d pWCS = resPointOff.Value.TransformBy(ed.CurrentUserCoordinateSystem);
double offset = IsRightDirection(curve, pWCS, pDir.GetAsVector()) ? resValueOff.Value : -resValueOff.Value;
DBObjectCollection curvCols = curve.GetOffsetCurves(offset);
foreach (DBObject obj in curvCols) {
Curve subCurv = obj as Curve;
if (subCurv != null) {
btr.AppendEntity(subCurv);
tr.AddNewlyCreatedDBObject(subCurv, true);
tr.Commit();
// Detect side of point
public static bool IsRightDirection(Curve pCurv, Point3d p, Vector3d vDir)
Vector3d vNormal = Vector3d.ZAxis;
if (pCurv.IsPlanar) {
Plane plane = pCurv.GetPlane();
vNormal = plane.Normal;
p = p.Project(plane, vDir);
Point3d pNear = pCurv.GetClosestPointTo(p, true);
Vector3d vSide = p - pNear;
Vector3d vDeriv = pCurv.GetFirstDerivative(pNear);
if (vNormal.CrossProduct(vDeriv).DotProduct(vSide) < 0.0)
return true;
else
return false;
Moderator
Alexander.Rivilis
Message 2 of 5 (726 Views)
Re: Offset polyline by pick point on side like autocad
02-04-2013 02:16 AM in reply to: xdbk07
using System;
namespace Rivilis
          if (btr != null) {
            if (pDir != null) {
        tr.Commit();
        return true;
      else
        return false;
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Hallex
Message 3 of 5 (717 Views)
02-04-2013 03:34 AM in reply to: Alexander.Rivilis
Nice solution
Hats off
Cheers :smileyhappy:
Active Contributor
xdbk07
Message 4 of 5 (692 Views)
02-05-2013 12:05 AM in reply to: Alexander.Rivilis
Great.It worked OK.
Thank Rivilis,
Valued Contributor
tanerpro
Message 5 of 5 (170 Views)
05-27-2014 10:32 AM in reply to: xdbk07
Hello Rivilis,
Thank you for the code, it works perfect with polyline and circle I tried but works inverse in case of line.
How can I solve this?
Windows 7 (x64)
AutoCAD 2012 (x64)
